The Reoccurring Code
Old Aug 18, 2008 | 05:51 PM
Camdisco24's Avatar
Default The Reoccurring Code
About every two months I get the following code: P0455. Every time I get it cleared and they say its you gas cap. Well I'm beginning to think its not because I keep getting it and I am VERY careful every time I put my gas cap on. Even my indy. mechanic cant find any problems. What else could this be? I am running out of answers and I am tired of having that light starring back at me.
Thanks for any help!
Cam
Old Aug 18, 2008 | 06:00 PM
Switzer's Avatar
Default RE: The Reoccurring Code
The emissions system pressurizes the gas tank and then checks for how long it takes for the pressure to bleed off. If it is too fast it will throw the gas cap code. You might have a leak somewhere on the filler neck.
Cheers,
Pete
Old Aug 18, 2008 | 06:05 PM
Buy a new gas cap. They do go bad.
Old Aug 18, 2008 | 07:14 PM
roverguy7's Avatar
does the cap bind before it clicks, if so, replace it... but yeah, lots of other things can through this code. purge valve, trickle valve, depending on what evap system you have, fuel tank pressure sensor, or lines to it, dmtl pump, vent valve charcoal canister... you need to get it checked out somewhere that can diag it, have them smoke test it, if it passes a .5 mm nitrogen test (theyll know what that is, if not, take it somewhere else) then you need to check the fuel tank pressure reading and purge valve opperation
Old Aug 18, 2008 | 08:24 PM
455's are not gas cap related.
Find a mechanic who knows how to test the system.
Old Aug 18, 2008 | 08:27 PM
Camdisco24's Avatar
ok thanks guys, I am having my guy take a look at the A/C which I still cant get to work, and I guess I'll add this to the list of things to do. Thanks
hatt53
Mar 27, 2013 05:16 PM
jbarr89
Jan 23, 2012 09:38 AM
sayeedA
Nov 15, 2011 11:02 PM
DiscoRover007
Aug 10, 2011 12:25 AM
Disco2Fever
Oct 2, 2009 03:57 PM
