Replace the front double cardan with a single cardan?
Old Nov 14, 2015 | 02:07 PM
fellipe's Avatar
Default Replace the front double cardan with a single cardan?
The front propshaft is gone and since in Brazil I cannot find an oem replacement, went to a propshaft shop and they told me they can install one from a 300tdi Defender.
I ve been reading mixed opinions if I can get rid of the double cardan and put a simple one.
What do you think?
Old Nov 14, 2015 | 04:55 PM
coors's Avatar
What do you think?
I would say you'll be fine if you plan to keep your Disco on-road (No off-road). Off-road articulation begs for a double cardon. With on-road driving your driveshaft should not be subjected to severe geometric angles.
Someone correct me if I am mislead, but you will be fine.
Old Nov 14, 2015 | 05:11 PM
fellipe's Avatar
Thanks coors
I guess I should have said that my disco has a 2" lift
Also, although I don't do any extreme off road, I do some green laning...
Old Nov 14, 2015 | 07:15 PM
Alex_M's Avatar
Personally I wouldn't risk it with the lift, especially since she's not strictly a pavement queen.
Old Nov 14, 2015 | 08:11 PM
coors's Avatar
Now knowing this new info; the single cardan will eventually fail. I would source a double cardan and park the DII until you can find one.
Do you have CDL? You can you pull the shaft (until the double cardan arrives) and drive around w/ the CDL locked.
Old Nov 14, 2015 | 08:56 PM
drowssap's Avatar
A new and improved shaft is approx. 250us and if shipping be the same amount. That still a lot less than the 750us your going to pay for an nos shaft if you find one.
Old Nov 14, 2015 | 09:01 PM
fellipe's Avatar
What is a nos shaft?
I can get a single joint cardan for my disco built for usd 150 here in Brazil.
If I need to import the price will double due to taxes. So that 250 shaft (never saw this price, all were above 300) plus 200 shipping plus 250 taxes will be usd700
Old Nov 14, 2015 | 10:48 PM
Welcome to Lucky8 Parts Club
Click on the service and repair parts (left side) once it loads there should be a big banner ad at the top for a replacement DII driveshaft for $228.00
Old Nov 15, 2015 | 12:07 AM
fellipe's Avatar
Does this propshaft have good reviews? I need to so it right at one shot as I wont be able to return it
Old Nov 15, 2015 | 12:10 AM
fellipe's Avatar
Also, what's the worst that could happen if I fit the single propshaft in my disco? Will it damage my car?
I wonder if it could be an inexpensive temporary solution...
