Replace Lug Nuts Disco 2 with aftermarket
Old Apr 17, 2017 | 09:06 AM
CoachTodd's Avatar
7th Gear
Default Replace Lug Nuts Disco 2 with aftermarket
Sorry if this has been asked before - I searched several different terms and combinations of terms, and couldn't find a definitive answer...
Can I replace the lug nuts on an 03 Disco 2 with generic aftermarket M14 x 1.50 lugs that you can buy from a local chain auto parts store? Or do I have to get OEM lug nuts?
Mine are pretty beat up and it's getting harder to get them off and on each time. Would like to just go to a solid chrome lug nut if I can.
Old Apr 17, 2017 | 11:54 AM
jafir's Avatar
You'll need lug nuts designed for the wheels. There are aftermarket available, but not at the parts store.
You can get solid steel, not capped, lug nuts on eBay for about $40 a set.
Old Apr 17, 2017 | 11:57 AM
jafir's Avatar
something like this:
Set (20) Land Rover Chrome OE Style Lug Nuts 27mm Hex 14x1.5 Fits Range Rover | eBay
Old Apr 17, 2017 | 02:14 PM
Best4x4's Avatar
Those look like LR3/LR4/RRS/RR lug nuts. D2/P38 RR are larger.
Old Apr 17, 2017 | 03:59 PM
jafir's Avatar
They say they have a 27mm head, which is the D2 size. The LR3 is 22 or 23 I think. The lug stud is the same size and pitch on them. M14x1.5 I think.
Old Apr 17, 2017 | 04:50 PM
Best4x4's Avatar
Yep I got home & looked at the link on my PC vs iPhone and yep those will work. Darn good deal IMHO. Just make sure you get all the washers. Last time I ordered a cheap set of LR3 lug nuts 2 of the lug nuts were missing the washers. I contacted the ebay seller and they sent me 2 replacement lug nuts, but if I had needed them ASAP I'd have been SOL lol.
Old Apr 18, 2017 | 10:59 AM
CoachTodd's Avatar
7th Gear
That is a good deal, OEM for basically the same price as something that may or may not work from a local parts shop. I ordered them. Thanks for the tip about the washers, for the link, and the advice.
Old Apr 18, 2017 | 01:53 PM
Luckyjayb's Avatar
That's a hell of a deal compared to elsewhere. A lot cheaper than britpart for $85 and up
Old Apr 18, 2017 | 07:00 PM
Best4x4's Avatar
No more silly aluminum caps to swell up, crack, or fall off. I went ahead and ordered a set as well before the price magically goes up like most stuff on Ebay these days.
I'll run them and save my perfect OEM set and I won't have to worry about getting a tire fixed and not taking off the lug nuts myself without damaging them.
Old Apr 18, 2017 | 08:20 PM
Luckyjayb's Avatar
Let us know how they hold up and go on. I'm gonna order a set this weekend or early next week
