Replace my Rotoflex?
Old Sep 14, 2021 | 06:05 AM
H Hill's Avatar
Default Replace my Rotoflex?
Good morning all!
My Disco 2 is in the local transmission/drive train shop for a rebuilt rear diff install. My cousin’s shop (one of the best in town) and he’s doing me a favor installing my rebuilt diff from Roverlands.
The truck has 278K and though the flex coupler is in good shape visually, should I go ahead and replace it while the diff is being changed? Lucky 8 sells them, as do others.
Thoughts from this esteemed group would be greatly appreciated!!
Old Sep 14, 2021 | 06:09 AM
mollusc's Avatar
It probably won't hurt, but whatever you do, make sure you don't go with the cheap rotoflex. Get the OEM one that's made in Germany. The other ones just don't last and you'll end up having to replace it again pretty quickly.
Old Sep 14, 2021 | 06:38 AM
redwhitekat's Avatar
good time to replace it with the conversion kit for a actual drive shaft
Old Sep 14, 2021 | 08:56 AM
whowa004's Avatar
Nothing wrong with the rotoflex if it's visually good, having a spare is always a good idea however.
Old Sep 15, 2021 | 05:17 AM
OverRover's Avatar
100% replace the RotoFlex and hardware.
IMHO ONLY use the GKN " Made in Germany" Roto, the cheap-o's are a huge waste of time.
THIS BOOGER>>>>>
Old Sep 15, 2021 | 09:23 AM
The_OGCJR's Avatar
I went with a conversion. Now I don’t have to worry about that damn thing
Old Sep 15, 2021 | 09:57 AM
redrover75's Avatar
Its the same part for BMW, which strangely is sometimes cheaper than the LR part. and probably easier to get at a dealer.
Old Sep 16, 2021 | 05:54 PM
JUKE179r's Avatar
Land Rover P/N: TVF100010 / GKN STC2794G
96mmPCD 12mmx6 bolts ID50mm, OD132mm, 30mm wide.
Discovery 1 & 2
BMW OE P/N: 26112226527
96mmPCD 12mmx6 bolts ID50mm, OD132mm, 35mm wide.
M3, M4, Z3, Z4
A stronger rotoflex - www.slunnie.com
Old Sep 16, 2021 | 08:13 PM
Best4x4's Avatar
I've honestly yet to destroy a Rotoflex coupling. All my D1/D2's are lifted 2 to 3inches and I've yet to have one blow apart. Do I carry a spare yes, but it's not brand new.
heidenseek
Nov 26, 2024 02:16 PM
Wheelspin
Nov 8, 2020 09:27 AM
WoodlandsLandRover
Nov 15, 2015 08:38 PM
oljohnboy
Dec 4, 2014 01:35 PM
oljohnboy
Jun 9, 2014 10:57 AM
