Replaced broken front driveshaft, now won't take gears
2002 Landrover Discovery2se. My front driveshaft fell out while driving home. We replaced it and it drove fine for a day. Now it will catch reverse once in a while, but no other gears, and yes it's full of fluid
ahab (02-22-2024)
In and of itself, a front propshaft change should not give the effect you are describing. The previous question about whether your transfer case is properly engaged is a good one! The question about the dash indicator matching the gear selection you have made with the gear shift is critical. If you "cheat" and try to move the gear shift just out of position, do you get engagement?
Micmac
03-13-2021 01:23 PM
Paul Grant
04-16-2018 06:44 PM
TRIARII
04-11-2013 05:25 AM
