Replaced the cooling system, expected one thing, got another...
Hey all! I just got done with a three-day tirade replacing all sorts of things. Valley pan gasket, valve cover gaskets, plug wires, etc. AND the entire cooling system except for the water pump. This includes every hose, the radiator, soft spring thermostat, radiator cap, throttle body heater. I even back flushed the heater core. SO... this is where things went differently than I expected...
With the old, leaky, Dexcool-plugged-up cooling system, per Ultraguage I was running 188 on the freeway and 196 in town. Maybe pegged at 202 sitting in traffic. Now with a fresh cooling system, BMW coolant, and the soft spring thermo, I'm running a consistent 203 on the highway, 207-212 in town, and sitting idle for 10 minutes, 208 with a quick peak at 215 but immediately back down to 210.
I'm assuming I have a couple more days of bleeding ahead of me, but overall, especially with the soft spring thermostat, I would expect at least what I had before. No? I know those temps are within spec, but still, just expected lower.
BTW, heater didn't work before back flushing, and now it'll singe my mustache. Good stuff.
Welp, fixed it... The new thermostat was bad and stuck closed. I happened to have another new one on hand, swapped it in, and lo and behold, back to the 190s. BTW, the bad thermostat was a brand new "soft style" from AB that wasn't the gray one.
I have yet to have a stat that doesn't open at its stated temperature.
You have to understand how this system works.
The hot coolant from the top T comes down and mixes with the cool coolant from the radiator. The flow is controlled by this mixing...the temp sensor is also on the other side of the block.
Why did they design it this way? Because huge influxes of cold coolant onto heated parts can result in slipped sleeves, warped heads, failed gaskets etc.
Well I just finished mine up and replaced all the coolant hoses, 180 thermostat drain the system hot flushed heater core flush radiator and even ran water through the engine through the top water pump hose. Bleeding this system is very simple! Running like a champ can’t tell of an exact coolant temperature because I’m only going by the gauge on the dash seems to be right in the middle like it used to be so who knows if it’s a 180 or not but it’s never overheated on me.
Your relying on your dash gauge that’s a big nono imo
For starters, the factory gauge is pegged at dead middle while the actual temp is oscillating between 170 and 240. That's the difference between me figuring out that the thermostat I installed was bad while blocks from home or waiting to find out it was bad after driving it hours from home into the wilderness.
