Replaced Crank Sensor, Runs Rough
Old 01-14-2015 | 03:59 PM
BigKyle99's Avatar
6th Gear
So, I re-installed the Crank sensor and cover, made sure that the harness had a good connection and I am still getting the same crappy running motor. Check engine light is not flashing at idle though, not sure if that is good or bad... Checked fuse #2, it is still good, exchanged it with a new fuse and still cant get a reading from the scanner... I am not sure when these other electrical problems occurred but, the radio, compass in the mirror and windshield wipers (front and back) are no longer working... Would they all be on the same circuit as the scanner?
Old 01-14-2015 | 08:00 PM
BigKyle99's Avatar
6th Gear
Also, I just found that the wires on the back of the passenger side knock sensor had been completely pulled out from the connector. As I understand it, the knock sensor could cause the issues that I am having with lack of power and it sounding like the timing is out of whack... Where can i find a new connector that will plug into the knock sensor? is my best bet going to a junk yard to find it? Thanks
CoMo
06-25-2014 03:34 PM
roverguy67
09-30-2012 11:39 AM
PK Disco 2
04-10-2011 02:28 AM
boldingm
04-24-2010 06:06 PM
mordor110
03-20-2007 02:21 PM
Quick Reply: Replaced Crank Sensor, Runs Rough
