Replaced differential, now I have a vibration...
Old Nov 2, 2020 | 08:51 PM
Brandon318's Avatar
Originally Posted by Dave03S
Have you tried rotating the tires to see if things change...
I have, and paid for a balancing and no change.
I'm super tempted to swap tires with the 2002 Disco, which are new, and see if the problem goes away, but what a project that would be. I'd almost rather just buy new tires lol.
Old Nov 2, 2020 | 09:11 PM
whowa004's Avatar
I think replacing 9 year old tires is never a bad idea, tho totally understand the hesitation due to cost. Having swapped tires between my discos a month ago or so I can tell you it's not worth it lol
Old Nov 3, 2020 | 11:32 AM
Harvlr's Avatar
But it's free troubleshooting
Old Nov 3, 2020 | 11:51 AM
Brandon318's Avatar
Eh, honestly, kind of needed new tires anyway, so I have a new set being installed this afternoon. Will report back.
Old Nov 4, 2020 | 12:14 AM
Brandon318's Avatar
Replaced tires, no change. Love the new tires though, haha.
Any way the radius arm bushings could cause this?
Old Nov 4, 2020 | 01:40 PM
swissarmychainsaw's Avatar
Originally Posted by PalmettoDisco
Before throwing money at it, try to balance with the two screw hose clamp technique. Place and tighten a screw clamp on the drive shaft, place a second one beside and place the screw opposite side of the other so they cancel each other out. Then rotate one a small amount. It should decrease, or increase, the imbalance. If better, move a little more until balanced. If worse, go back to direct opposite and move in other direction until balanced. If for some reason you need more weight to balance add two more clamps and move as needed.
This is brilliant and cheap. Did you try this?
From what you have posted: Vibration exists with driveshaft and does not without it.
I would try the above and/or have the shaft balanced at a shop. That sounds cheap to me!
Old Nov 4, 2020 | 02:03 PM
Brandon318's Avatar
I haven’t yet but I’ll give it a shot. Any spot along it’s length I should place? Or does it matter...
Old Dec 10, 2020 | 11:55 AM
Brandon318's Avatar
Still working on this issue. My 2002 drives glassy smooth - can I swap over it's driveshaft to the 2004's to 100% rule out (or confirm) the driveshaft being the problem? 2002 driveshafts are a little longer than 2004s, right?
Old Dec 12, 2020 | 07:31 AM
briancbev's Avatar
I've got the same problem and have had it for years. Purchased several different driveshafts (never the TW tho), rebuilt the original driveshaft, and even replaced the front output bearing on the TC. It is smooth as glass when I drive with the front driveshaft out and the CDL locked, but when I put it back in, I get the same vibrations you do. Regarding 2002 vs 2004 driveshafts, I've never heard that they are different lengths, but I have a 2001, so I wouldn't have a reason to know.
Keep us posted!
Old Dec 12, 2020 | 01:05 PM
acg's Avatar
acg
Pre-2003s use the 4HP22 transmission. The 2003/2004 uses the 4HP24 transmission to accomodate the higher torque of the 4.6L engine. The 4HP24 is slighty longer which results in a relatively shorter driveline. However, you should be able to transplant the 2002 driveline to the 2004 as the splined shaft should be able to take up the difference in length.
san988
Nov 27, 2025 02:36 PM
PAPAGALLO
Jan 23, 2017 06:23 AM
bcolins
Apr 20, 2014 01:29 PM
oysterhead
Oct 28, 2009 09:56 AM
LiftedRover96
Feb 7, 2006 10:41 PM
