Replaced Radiator now another leak
ok Replaced the radiator that was bad and new hoses. not a fun job lol but now I get a leak when up to temp around the water pump drivers side. On the image it looks like it is coming from the back side of the pump area around the two left 11mm bolts. The top bolt is wet on the threads and gummy with crap and the bottom one was dry. took the pump off it looks fine and the gasket looked good. And when it leaked it was about a quart or so of coolant
Any ideas? or is my block gone?
oh yeah that I didn't there are 3 11mm bolts that are longer and they only thread into 3 specific holes on the pump. I am just trying to figure what could be totally wrong right now before I go out a spend more money. This hasn't been leaking there untill after the rad was replaced. and wasn't touched druring this other than removing the fan from of it.
You replaced a leaking radiator, and the coolant system is pressurized, so it's not uncommon for new leaks to happen, because the coolant is now escaping from where ever the next weakest point is, whatever gasket or hose that is worn out from heat cycles and pressure.
The coolant leak may not be from the waterpump, but the timing cover behind it.
It is also possible that it could be dripping down from between the block and head(s), or block and lower intake manifold.
The block itself is probably fine, and coolant leaks on these old engines are normal.
Once you fix that leak, don't be suprised if a new leak starts somewhere else.
and changing the timing cover probably a pain in the *** i bet too. and if it leaking it wont pass inspection like it is
