Replaced Stock Subs in same housing? - make a diffrence
Old May 3, 2022 | 10:59 AM
SWM's Avatar
SWM
Default Replaced Stock Subs in same housing? - make a diffrence
For anyone that replaced their stock subwoofers in the same housing with the rest of the system remaining stock, did it make a difference?
I know the only way to real subwoofer performance is to upgrade the system/amp, head unit, etc but I am looking for feedback from anyone that simply unscrewed their stock 6.5" subwoofers and replaced with aftermarkets retaining the rest of the stock system. I know others had to replace theirs due to age and wear so I hope I can get some feedback.
Old May 3, 2022 | 11:50 AM
WaltNYC's Avatar
It doesn't need to be that difficult. New drivers will help, but not that much. Add an amp for the subwoofer only. Use high level inputs and drop the amp in the pocket next to the subs.
I use these drivers which sound really good in my D1...
Amazon Amazon
and find a mid-power mono amp.....
Amazon Amazon
Old May 3, 2022 | 12:31 PM
SWM's Avatar
SWM
Where did you pull power from for the amp? I like the ability to hide the hardware and keep the stock appearance.
Did you have to do any modification to fit the drivers or direct drop in?
Old May 4, 2022 | 06:00 AM
PickleRick's Avatar
I put some skar 6.5 woofers (not subs) in the back door. Had to cut some metal out to make them fit.
As for sound, they rattle everything if a song hits certain bass notes. You can hear it inside and outside
I put pyles in all the doors and still using factory tweeters.
Honestly, the back woofers need to go and some proper sized 10" subs installed in the the storage spots in the trunk aka where jump seats would go if you want great bass without losing trunk space.
For highs and mids the factory system is great for stock. Rivals my monsoon system in my VW.
Old May 5, 2022 | 10:25 AM
WaltNYC's Avatar
The drivers drop right in. No mods needed.
The D1's have an small amp in the same box as the woofers, I used power from there. Is there a cigar plug/socket in the rear of the D2?
Old May 5, 2022 | 10:29 AM
SWM's Avatar
SWM
Probably not much juice from a cigarette lighter but I may try a more sensitive sub and see if that adds enough bass for me. That way, if it needs a line level amp, I would have capable speakers there already.
Old May 5, 2022 | 12:38 PM
TimInNova's Avatar
I use these drivers which sound really good in my D1... https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Did you get the 4 ohm or 8 ohm version?
Thanks
Old May 5, 2022 | 12:41 PM
SWM's Avatar
SWM
Thanks
I was just going to ask the same thing. What ohm are in the truck currently? I don't want to over run the amp
Old May 5, 2022 | 02:13 PM
SWM's Avatar
SWM
or does anyone know what the factory amp is rated for (ohms)
partsguru
Oct 16, 2015 08:10 PM
Classklown90
Audio/Visual Electronics
Dec 10, 2009 08:03 AM
SpeedAgent
Aug 1, 2008 02:37 PM
andrewkim06
Mar 8, 2007 09:19 PM
skrach77
Jun 4, 2006 12:20 PM
