Replacement parts brands
Rebuilding an engine. Any brands or vendors of parts to avoid? Needing gaskets, rings, valve guides and seals, bearings, rod/head bolts, etc. Prices vary greatly from expensive genuine oem to cheap aftermarket and eBay.
I'd go genuine with internal engine components.
You'd probably be ok with aftermarket gaskets.
My experiences with the cheaper aftermarket parts are hit or miss, especially allmakes4x4 (which I avoid if I can).
I had a water pump last 12k miles before the bearing exploded, a brand new power steering pump dead on arrival, and new timing gears that were cast poorly and didn't fit.
Like that except for the composite exhaust manifold gaskets. Tried them twice always leak, the layered metal gaskets are the way to go.
Anyway, the Reinz gasket kit does not include head bolts and I had to get them separate. The head cover has a really nice tab on the side with the name Victor Reinz.
I prefer el-ring head gaskets.
For engine rebuilding, get what parts you can from Turner Engineering (uk). Their prices are the best (bearings, rings, gaskets, etc) and they are pro rebuilders, so what they use is good enough for me.
