replacing engine
Old Dec 13, 2010 | 10:03 PM
scooter22's Avatar
7th Gear
Default replacing engine
i have a 2002 discovery II with 130K miles. I am thinking of having a rebuilt engine installed. I am concerned that another expensive part will fail transmission etc. Any words of wisdom? Thanks
Old Dec 14, 2010 | 03:20 PM
dynomite's Avatar
why are you replacing your engine?
Old Dec 14, 2010 | 03:55 PM
hilltoppersx's Avatar
yeah, why are you replacing your engine? the transmission is one of the best parts of these trucks so unless your driveshaft goes thru it, it should be in half descent shape.
Old Dec 15, 2010 | 06:25 AM
scooter22's Avatar
7th Gear
Thanks for replying to my problem. I am forced to replace the engine since it has been leaking oil and antifreeze. I was driving on the highway the temperature guaged pegged high and by the time I was able to get on to the shoulder it overheated and lost compression. I was going to ask about the transmission. with 130K miles do i have to worry that it will be the next to go or should i have many more miles before that happens. when the engine is replaced is there anything special to look for with the drive train including the transmission.? thanks for your help. To some it does not make sense to put 4 or 5 K into the truck. I think it does, other then the engine the truck is in great shape.
Old Dec 15, 2010 | 06:35 AM
scooter22's Avatar
7th Gear
hi hilltopersx, first thanks for your reply. I did not know tht there was a land rover club in the northeast. Where are most of the members located? I live in New Jersey. Do you know of any good shops in the area that work on land rovers. The land rover dealer that I have been talking too will replace the engine for $3K. I found a rebuilt from cannibal rover in Oklahoma I was wondering if anyone heard of them? Thanks
Old Dec 15, 2010 | 06:39 AM
transmission will be fined just service it with a new fluid and filter. same with the transfer case and diffs. if you are going to buy a used engine then i would say do all the gaskets before installing the engine (i like the kit from AB), new 8mm wires (magencor, STI or Kingsborne), plat plugs (i like bosch plat +4), new thermostat, water pump and you should be good to go!
Old Dec 15, 2010 | 06:43 AM
where in Jersey are you? i would stay away from cannibal if i were you i have heard some bad things. instead go to someone who is trusted like roverland i have trusted links on our club website here is the engine i would put in your truck
http://www.roverlandparts.com/1999-2...y55kmiles.aspx
here is the head gasket kit
http://www.roverparts.com/Parts/STC4082BK.cfm
nicksrover
Jan 6, 2015 11:25 AM
Savannah Buzz
Aug 17, 2013 09:42 AM
oregon_husker
Jan 16, 2013 09:22 PM
rlrigsby
Feb 18, 2010 03:42 PM
Jrsmith70
Aug 26, 2009 04:09 PM
