Replacing Front brake Disco I
I have a 1995 Disco I,my front rotors sqeaks plus have grooves intthem, iwant to replace then but not to sure. Ihave been looking at diffrent fourms on here and even a manul but I have a quick question, are therotors pressed on or can they be taken off pretty easily? I see how to take off the hub, that doesnt look to bad to do, but just curious on the rotors. i dont want to start and get caught in the middle and not be able to finish. Any help would be great thanks
i'm actually tearing into my rear brakes this saturday for a bit of an overhaul... from the looks of it its a tad more involved than the fronts... hub, axle shafts, the whole bit has to come out... i will try to get some pictures and document the undoubtedly catastrophic outcome for everyone...
________
thai girl Cam
________
thai girl Cam
Finally got some time and motivation to fix a leaking rear seal this past summer..Found that the rear seal was in backwards .. Check this out good info http://www.bb4wa.com/articles/wheelbearings.htm
ORIGINAL: discoxd
mike, grease seal?
mike, grease seal?
If you were really going to take care of your truck, you should check and fill the swivel joints, check the preload and drain the diff .
