Replacing front wheel bearing
Old Jan 4, 2012 | 10:33 PM
CapebretonIsland's Avatar
Question Replacing front wheel bearing
Hi! Has anyone here had to replace a front wheel bearing? Mine front left has been needing replacing for a while. I've been checking parts online and I see wheel bearing kits for sale for around $50. However I called the LR Dealership to price the part and they said that there is no such kit and that the entire hub(??) must be replaced. The part is expensive- $750(CA). I would appreciate advice from anyone with this experience.
Thanks, Kerri
Disco2- 2001
Old Jan 4, 2012 | 11:30 PM
kenk's Avatar
Unfortunatly, they are correct. But, aftermarket ones can be had for much cheaper. $320 @ rovahfarm.com,
Old Jan 4, 2012 | 11:53 PM
bosshogt's Avatar
I replaced my front right one with a used one on eBay. $50 and its been smooth for 2 years now. They are on eBay. You can also call Drillbit or Marty, he probably has plenty.
If your doing it yourself you need a 3 arm puller. Not a bad job 2/3 hours. Be gentle with the ABS sensor, its removed with a regular philips screw.
Marty Powell
Giver of Last Rights to Fallen Rovers
270 576 7922
Old Jan 5, 2012 | 04:16 AM
See Discovery II Hub Assembly With ABS Sensor - Land Rover Parts & Accessories for a pix of the whole thing.
Old Jan 5, 2012 | 05:13 PM
Livingintheskies's Avatar
www.discovery2.co.uk / Front Wheel Hub / Bearing Assy
Good write up and amazingly knowledgeable guy. good luck.
Old Dec 22, 2012 | 12:41 PM
Climbs's Avatar
7th Gear
Default Really?
Doing the breaks and hubs now and the bearings are shot on at least one front hub on a 2001 DII. Are you all sure that the hub is not serviceable? The only way is to replace the whole hub?
Seems like you could extract and repress bearings? Not an expert here. Looking for an economical option.
Thanks
Old Dec 22, 2012 | 12:48 PM
lr2001silver's Avatar
Banned
In the administrators signature is contact info for our trusted used parts sources Paul Grant is a heck of a guy to deal with and his prices are right! I think he has stripped down around 36 trucks this year and he really knows his rovers!!!
Old Dec 22, 2012 | 03:05 PM
I would call Paul for sure.
Old Dec 22, 2012 | 04:23 PM
Nftyper's Avatar
Thank you for that link, much needed.
Old Jun 26, 2013 | 07:37 PM
ShaggySE7's Avatar
called Paul and bought a used hub from him. I'll be doing this over the coming weekend. 320 ft lb is crazy high. I have access to a 250 ft lb wrench. Guess I'll take it to that and a little extra for good measure!
