Replacing the plastic cover inside the door
Old Nov 13, 2019 | 04:26 PM
mr. choodles's Avatar
Default Replacing the plastic cover inside the door
Howdy folks,
Has anyone figured out an alternative to the plastic cover that sticks to the door frame? Given the age of our trucks, that plastic is getting old and the glue is pretty nasty. Perhaps it is possible to create an alternative that is easier to remove/replace... Has anyone done anything like that?
Old Nov 13, 2019 | 04:39 PM
Sixpack577's Avatar
I think the glue is butale tape, and you can buy more plastic at a hardware store.
You can clean off the goo and go back with rtv silicone that easily peels off when dry.
It's the easiest way to keep drafts and moisture out.
Old Nov 13, 2019 | 05:30 PM
Extinct's Avatar
Yes I have - get the carpet protector from Home Depot. It is on a roll, 24" wide, adhesive backed, quite thick and not brittle.
Old Nov 13, 2019 | 06:56 PM
Best4x4's Avatar
Shower curtains work
Old Nov 13, 2019 | 07:16 PM
OverRover's Avatar
Home Depot / Lowe's has 6 Mil Clear or Black Plastic Sheet in many lengths.
OR use some cut in half Contractor Clean-up Trash Bags.
LeakyDisco
Apr 7, 2025 04:34 PM
Aeteocles
Nov 9, 2019 12:39 AM
0304Disco
Oct 29, 2013 10:32 AM
Rover_Hokie
May 12, 2012 04:27 PM
drewbiedoo
Nov 28, 2006 01:40 PM
