replacing radio with used one from ebay
I am in need of a radio because the volume button doesn't work to well.
I am going to buy a used on off ebay sometime soon and I thought I read somewhere that it needs to be activated.
Is it just a plug and play setup or will the one I get need to be activated? and if so, how does one activate it?
Thanks for the help.
Just as a note, I swapped out the OG unit for a Kenwood and used the same speakers. I have the low line system, S Model... My point being that the same speakers sounded 100% better with a different head unit. If you got a few extra bucks and you care about the sound quality rather than the look, go aftermarket.
Exactly what I did, put a 3 channel JL amp under the passenger seat where the factory CD player goes, that feeds the two front door speakers and a sub in a box in the back.
The original amp still feeds the back door speakers which sound inferior to the rest. If I had the time I could try to figure out how to use the head unit to power the back seat speakers instead of the factory amp. Another day maybe since I don't ride much back there.
Rover_Hokie
11-20-2012 08:50 PM
bcolins
07-05-2011 08:30 AM
raid13
06-16-2007 08:16 PM
