Replacing a water pump as PM?
I'm not sure where I got this idea, but it is seeming rather odd now. I'm changing out my radiator, t-stat, and serpentine belt. Belt for services, radiator because it is leaking, and t-stat for PM. I'm not sure where I got this idea from, but I was going to replace the water pump while I was down there. What is the average break-down interval for a water pump? Is it worth it to replace while everything is off and coolant is drained? It is a 2003 disco with 60,000 miles.
Thanks!
Thanks!
RE: Replacing a water pump as PM?
I've been reading viscous clutch horror stories, so it is starting to make sense to change that joker out too. Theclutch from atlantic british is currently marked down to 180 bucks. I'm going to have to order those two special wrenches for the viscous fan also, looks to be about a hundred bucks total. Any alternatives to that one?
ORIGINAL: 98roverguy
Not to turn this into a money pit, but you may want to replace the fan too, they get brittle and can fly apart putting a dent in your hood (so I have read).
