Resetting Service Engine Light
Old Mar 8, 2009 | 07:26 PM
adwarren78's Avatar
Default Resetting Service Engine Light
Can I reset the Service Engine Soon Light myself.
Old Mar 8, 2009 | 07:36 PM
Why would you wqant to reset it, what are the code numbers and have you made the necessary repairs?
By the way, no you can't reset the codes unless you have the proper scanner.
Old Mar 8, 2009 | 07:44 PM
SDinDS's Avatar
Do you mean the red Service Engine Soon light? If so, you can reset it.
Eric
Old Mar 8, 2009 | 07:45 PM
You need a OBDII scanner to read and reset the light.
You can get one almost anywhere.
Old Mar 8, 2009 | 07:47 PM
Eric
DI's have two lights, a amber "check engine" light and a red "service engine soon" light.
The red one can be reset by the owner.
On DII's there is only one light, "service engine soon" and cannot be reset without a scanner.
Old Mar 8, 2009 | 08:00 PM
adwarren78's Avatar
The code was P0455. I found it had a loose gas cap so I tighten it. The code hasn't gone away yet thought I might have to reset it. The truck has 59,270 miles thought it also might have been the 60000 mile service warning
Old Mar 8, 2009 | 08:02 PM
adwarren78's Avatar
Thought I might add its a 2004 Disco II. The light was also amber
Old Mar 8, 2009 | 08:45 PM
SDinDS's Avatar
My bad. Didn't know there was just one. Sorry for the confusion.....
Eric
Old Mar 8, 2009 | 08:54 PM
IDAHODISCO's Avatar
If its fixed your light will go off I just did the induction cleaning and tripped my light it went off after 5 start cycles!
Old Mar 8, 2009 | 09:09 PM
A 455 code will not go away on its own, no code will except for a soft code like one thrown when doing an induction cleaning.
A scanner is the only way to clear it and a 455 is a gross evap leak normally not caused by a gas cap being loose.
You will need to have some track down your vapor leak.
