Richard head gasket replacement 04 Disco II
Old 02-23-2020 | 02:56 PM
Richard Gallant's Avatar
A few pictures of Saturdays work, an old cleaned up dishwashing soap bottle makes a great oiler.
Cleaned all the push rods, liberally oiled the rockers, valve tops, rover springs, lifters, oil holes under the rover arms and camshaft After a good vacuuming of course.
As noted a short day I had family obligations, but it felt good to get the heads and rockers done and torqued.
  #42
Old 02-23-2020 | 04:29 PM
Brandon318's Avatar
Originally Posted by Richard Gallant
No pictures a long 3 day week end and I got the heads in place, with the rear bolt on the driver side holding me up, I need a small headed 3/8 torque wrench to get in there. Wobbles do not give enough room. Found a perfect sized one, but it is in inch lbs.
Cleaned up a few bits I have a line on a 3/8 that should work.
How'd you get the braided loom over the connector?
  #43
Old 02-23-2020 | 04:49 PM
@Brandon318 it is a split loom that overlaps, it is is really nice stuff. I have some more to do, I will get some pictures of what it looks like going on to the wire.
  #44
Old 02-24-2020 | 10:52 AM
Sunday was a good day
The valley pan gasket is a pain to get set just right, it takes a lot of fiddling to seat correctly - in my case the left side was great the right side took some work,the right rear was great the right front was low a bit. If you do this read a lot and dry fit a few times.
I suspect a lot of the issues around leaks in this area are related to fitting issues.
Bolt cleaning took a lot of day, turns out the old intake bolts had plumbers paste on them, that is just wierd as the bolt do not enter the cooling jacket.
After 5 days of soaking in gasoline that stuff was still hard as rock. As luck would have it the only thread chasing kit to rent was out.
In the end I used my old warped head as a chase and used this process:
  1. hit the bolt with gasket remover spray
  2. Screw the bolt into the head
  3. Let sit for 15 minutes
  4. Pull it and rinse (hot water)
  5. Scrub with a bristle brush
  6. Clean grooves with an exacto knife and jewelers screwdriver - this stuff is hard
  7. Run into a second block hole with degreaser
  8. rinise again
  9. Run into the block in a 3rd hold dry
  10. Repeat if required
I generally had one soaking in gasket remover while I cleaned the next one.
Before and after
State of intake bolts
Once the intake was in place, I got the SAI pipes into the block, after adding some anti seize. They are supposed to torqued that is hilarious with a square fitting.
My day was coming to end at this point as were High winds forecast so I got everything battened down, but for amusement my work area.
3 step ladders and a halogen work light
Final job was replacing the throttle body heater, mine leaked and has been bypassed but as long as everything was apart, I figure replace it.
It is very easy:
  • pull the old one
  • Clean the mating surface,used 2000 grit sandpaper and steel bar
  • Copper gasket spray on both sides of the gasket
  • Set the gasket in place
  • Put the manifold in place
  • Bolt it down
  #45
Old 02-25-2020 | 09:41 PM
Well started and stopped today, got laid off need to clear my brain. Put the AC bracket on and forgot the lift eye, figured put the tools down take a day have lots of time now.
whowa004 (02-26-2020)
  #46
Old 02-25-2020 | 09:45 PM
No Doubt's Avatar
Dang! Sorry to hear.
Richard Gallant (02-26-2020)
  #47
Old 02-25-2020 | 10:01 PM
@No Doubt yea 62 in 2.5 weeks hell of day - but it is not the1st time, and wife says just retire we will figure it out. So she's a keeper for sure
The following 4 users liked this post by Richard Gallant:
Dave03S (02-26-2020), No Doubt (02-26-2020), Sixpack577 (02-26-2020), whowa004 (02-26-2020)
  #48
Old 02-25-2020 | 10:45 PM
redwhitekat's Avatar
what’s your line of work
  #49
Old 02-26-2020 | 12:23 AM
@redwhitekat IT support legacy systems and integration to Windows. But I have done a lot stuff in the last 40 odd years, mostly computing related, ran my own computer store for a while, was a programmer analyst, ran data and telco cable for a few years, did commercial side support for an Antivirus sales outfit,some data recovery.
Before all that I worked doing sheet metal work for Force 10 Marine, stove, barbecue etc for yachts, ran a gas station for a couple of years, a couple warehouse jobs. Did a lot misc jobs early on I spent 25 years as a reservist, took a lot of short run postings (deployments in modern terms), into my middle 20's.
I am sort misc jobs guy, my wife has worked for the same company for about 32 or so years.
Funny story I was laid off by the original owners of the company about 20 years ago, when money was tight. Came back 8 years ago under different owners, the company was sold to a US equity firm and I get laid off again technically by the same company. The world is a funny place
The following 2 users liked this post by Richard Gallant:
  #50
Old 02-26-2020 | 09:36 AM
whowa004's Avatar
Sorry to hear, sounds like if needed you can find something to keep you busy!! and if not plenty of time for more exploring
Quick Reply: Richard head gasket replacement 04 Disco II
