Intake off , found I did not tighten the passenger side valve cover bolts correctly.
go the coil packs bolted down that was 45 minutes of frustration I am really starting to hate SAI, sad thing is the lower bolts are easy the top 2 not so much
Plug wires routed
Various hoses etc connected
AC compressor back on
Throttle cables connected
Tomorrow after a dentist appt :
review upper engine cable and hose runs
Torque upper intake
Torque A/C compressor bolts
Torque Spark plugs and install cables
Install secondary air
Install exhaust
Oil & filter change
Install and double check all cooling system hoses
Install alternator and battery
Water and prestone flush into the cooling system
And start with luck -I have a few ex job things to take care of start might be Tuesday
Sounds good. Keep a fire extinguisher handy for your first start after a rebuild. Spray from underneath up, not from top down, if needed.
Best to have a 2nd person away from the vehicle, but on the ground low, looking up at cats for any sign of red/orange/purple glowing during the initial breakin. Also looking for any leaks such as oil, fuel, brake fluid, power steering fluid, or coolant.
20 minutes of being diligent can really up your safety factor during that break-in.
Less work that expected a few other things interfered, but a good short afternoons work.
Less 2 hoses and IAC (big aluminum canister on top of the Intake) the left side is complete
1st oil change done and there was clear water from the pre disassembly cooling system flush in the oil not much maybe a 35mm film canisters worth but some
Just the right side to do
torque spark plugs
exhaust
secondary air bits
Cooling system fill
Alternator
Thinking happy thoughts and less rain, 4 deg C and heavy rain the last hour gets right into your bones
On to Pictures
Start of the day Exhaust gaskets ready to go End of day right side End of day left side rain, I missed getting as shot of the lets see if he has an ark downpour minutes before
Why spray from bottom up? Just curious. On first take that’s counterintuitive.
Beats me!
Kidding aside, the #1 reason to spray from below angling up (e.g. lying on the ground looking up at an angle, not directly underneath of course) is to avoid opening the hood.
Murphy's Law is that you won't get the fire until you close the hood, thinking that all is well. Well... don't open the hood back up if you get an engine fire! Simply spray in from the underside.
Man there is always something 2 of the right side exhaust manifold bolts will not go in.
Exhaust manifold back off
Chase a bolt and threads slowly work the bolt in with a bit on engine oil - success
Then dropped the damm spacer, when I took the bolt out and it did not hit the ground
The day from hell 7 hours and the passenger side exhaust manifold is still not on.
Everything started so well, no rain got the plugs torqued ignition wires run, then doom struck :
The manifold drops in without issue, but the rear 3 bolts will not line up 2 upper far lower
Threads appeared to be getting damaged so drive 45 minutes (round trip) to rent a thread chaser set
Get everything cleaned up drop a spacer, one thud and nothing
2 hours later I found it, it had the frame rail roll between 2 cables and ended up about where the cat is found with my inspection cameras. I was concerned it had lodged a somewhere bad.
More fiddling and cursing the bolt holes will not line up, got to love chopsticks as a bolt substitute
After a lot of fiddling it appears I need to pull the Y pipe down, so tomorrow :
Undo the driver side y pipe nuts
Suck that thing down with a couple of cargo straps
