Rocker Shims
There is nothing exotic about rocker shims. I have made them out of sheet metal before. Just make sure the metal is the thickness of shim you need. Cut out a small piece about the size of the rocker pedestal and drill a hole thru the middle. Viola.
I cannot remember how the Rocker V8 rockers are oiled. If they are oiled thru one of the rocker pedestals, make sure the hole you drill is the same size as the opening on the rocker pedestal. That's how Small Block Dodge's are.
So, I'm not understanding how surfacing the head can mean that you need shims. If you've skimmed some material off the underside of the head, you've slightly shortened the distance between the rocker arms and the tappets/lifters. That is, the push rods/tappet assemblies are the same length, but the distances from the bottoms of the tappet bores to the rocker arm cups are now fractionally less. A shim (in the bottom of the tappet bore?) will increase the length of the rod/tappet assembly, which seems to be doing the exact opposite of what you would want to do to offset the effect of skimming the head.
Generally if you have a good machinist, they'll also grind the top of the valve to make up for the amount the head was cut unless you cut it too much.
nosup4u
08-19-2014 08:11 AM
