Rod Knock or Slipped Liner?
Old Feb 11, 2018 | 07:05 PM
number9's Avatar
Sounded somewhat similar to mine when the belt tensioner was jumping around.
the tensioner pulley bearing is shot, feels really crunchy and loud when I spin it by hand.
Buy a new tensioner assy which includes a new pulley. They can wear out, jump up/down and cause your knocking sound. Ask me how I know.
Old Feb 11, 2018 | 07:14 PM
sickws6's Avatar
Almost guarantee nothing related to the tensioner or anything else external or ignition of oil thickness etc. mine sounds exactly the same. I tried everything, exact same symptoms as yours. Only at temp, goes away with RPMs etc.
Old Feb 11, 2018 | 07:23 PM
number9's Avatar
Originally Posted by sickws6
Almost guarantee
Only counts in horseshoes.
Old Feb 11, 2018 | 07:43 PM
sickws6's Avatar
Lol guess your right.
Old Feb 11, 2018 | 08:37 PM
DiscoCam's Avatar
Well it doesn't matter if the tensioner is the cause of the knock or not, it's bad and needs to be replaced. Just ordered the Gates tensioner assembly on Amazon. I took the belt off and ran the truck for about 30 seconds, I don't think I heard it anymore. Attached is a clip from the same location, no belt. Engine was at operating temp, probably a little higher because the water pump wasn't moving.
I still have a hard time believing that it has a slipped liner because the head gaskets were replaced very recently by an LR specialist so I'm pretty sure that they would've checked for slipped liners. Not ruling it out though.
Number9, I missed your first question. The knock does stop a few times. No editing tricks or recording issues, that's just how it usually sounds.
Tensioner is supposed to arrive on Tuesday so I'll install it then and report back. Thanks everyone.
File Type: wav
Old Feb 11, 2018 | 09:01 PM
number9's Avatar
Looked back at the PNs you mentioned and see you were going with the assembly rather than just a pulley.
The tick pausing was similar to what I heard when mine was bad, was able to see it jump with a close look and light.
Good luck.
Old Feb 13, 2018 | 05:16 PM
DiscoCam's Avatar
Good luck.
Replaced the tensioner assembly today and now it sounds exactly how it did with no belt. I noticed the crankshaft pulley wobbles a bit, so I have a feeling that's what wore out the tensioner. It was a Dayco unit, not sure if that's the original or not. Thanks number9, looks like you were correct. Only thing is that I think I have to replace the crankshaft pulley in the future. But the noise is gone from what I can tell. I post a sound clip soon.
JimmyChooToo
Jun 8, 2016 08:54 AM
Sarge103
Jan 9, 2016 03:04 PM
expedio2005
Mar 15, 2015 10:45 PM
utah95
Feb 14, 2014 08:47 AM
TurboLS1Driver
Jun 19, 2012 09:04 PM
