Roof Rack Seal install - tricky?
The Deputy (07-11-2021)
And, l'm not so sure that the headliner has to come out...EDIT...it looks like it does.
Yes, but the diagram above indicates they fit the 04. I think LR did not update the parts diagram for the 04 model year. I cannot find any parts pictures that show the 04 bars. I wrongly assumed the picture was not correct and the parts were correct. I am now thinking both are wrong. Will see what I get when I take it apart.
I'm pretty sure the 04's (which I took apart once) just have the rubber seal you can see from the outside of the car when the rails are mounted. In that case, I'd re-use them as I think they are NLA and just put a circle shaped bead of black sealant underneath at both mounting points (careful with amount so it doesn't squish out and look a mess on the paint).
