to roto flex or not to roto flex...
Old Jun 1, 2009 | 01:33 PM
Default to roto flex or not to roto flex...
Ok, all of you with a 1997-1999 DI do you have a roto flex on your rear drive shaft or a u-joint at the rear differential?
Old Jun 1, 2009 | 02:41 PM
hazletbassist89's Avatar
My 96 has the rotoflex but between the 126k miles it has on it and my lift coming up hopefully soon I have been weighing the possibility of either a new one or the u joint conversion. What exactly is the difference? Actually I really only need to know which is better if any off road.
Old Jun 1, 2009 | 02:58 PM
Spike, why are you asking??
As long as you don't exceed a 3" lift you won't have any problem, except once every 80,000 to 100,000 you will need to replace it.
Old Jun 1, 2009 | 03:03 PM
I am asking Mike because there are conflicting reports on what years came with a roto flex and what years came with u-joints.
My '97 has 4 u-joints, so have a couple of other year on here, so I am just trying to see if we can confirm or deny the fact/myth that 4 u-joints were standard on some modle years of the DI.
Mitch-it all comes down to personal preference, neither is better than the other on stock suspension, with a big lift the rotoflex will fall apart.
Old Jun 1, 2009 | 04:11 PM
Jull's Avatar
I own a 98 and I don't have the rotoflex. And with the mileage on my truck, the previous owner definitely didn't get the conversion to u-joints.
Old Jun 1, 2009 | 04:17 PM
tango123's Avatar
how can you tell the difference between a rotoflex and u joint?
Old Jun 1, 2009 | 05:50 PM
If you want to do the convertion you will need this kit.
http://www.roverparts.com/Parts/9300.cfm
This is a u-joint out of the truck.
http://roverparts.com/Parts/3092.cfm
This is a roto flex.
http://roverparts.com/Parts/TIJ000012G.cfm
The roto flex is a piece of rubber, that all, rubber.
This is what the u-joint looks like on the truck, the brass looking this is the grease zert, or nipple.
[IMG][/IMG]
Old Jun 1, 2009 | 06:34 PM
Rover Chris's Avatar
my 97 has a roto flex (and it looks like it may need to be replaced soon) I am asuming that this item is designed to "flex" up and down as the truck goes over bumps, is it made of like a hard rubber or something?
Old Jun 1, 2009 | 09:07 PM
NiteTrain's Avatar
chris, yeah it's made out of hard rubber. It eliminates drive line vibrations (think BMW ride component and German over engineering) I know some people on here wheel their rovers hard and haven't had a problem but when mine needs replacing I'm going with U-joints.
Old Jun 1, 2009 | 09:16 PM
grussell's Avatar
My 97 has 4 U-joints. I never asked why my u-joints have grease fittings and my drive shaft has grease fittings too?
I have changed the "Guibo" on my wife's 525 and it is a bear. You have to drop the exhaust to get to it, and even on jack stands there is not much clearance.
