Rough idle until warm
Old 09-15-2010, 08:20 PM
cwood's Avatar
Problem solved....maybe.I decide to pull the #4 plug due to p0304 code"#4 cylinder misfire". After closely looking at the plug I found a crack in the porcelain which I thought I may have did while I was removing it, installed another plug,stated it and it ran fine. Went back today same thing started and ran great. Shut it down and cleaned the TB,checked for vacuum leaks also. Will change plugs in a few days.
Now I need to resolve the issue of my battery draining down,after searching the site I think that it is the ABS module under the hood,it seems to run or to be humming all of the time.thanks again for all of the help.
Old 09-15-2010, 08:34 PM
lipadj46's Avatar
It is normal for the ABS module to hum for 10 or so minutes after shutdown. There is a TSB though if it never turns off, requires a trip to the dealer.
Old 09-18-2010, 07:43 AM
cwood's Avatar
Rough idling until warm problem is solved. SES Light did come back on bit I am waiting on my scan tool to arrive to address that. I checked the ABS module after sitting all night and is was still making noise, any idea of cost for dealer to fix or reprogram it.thanks,CW.
Old 05-30-2011, 10:30 PM
bentonrover's Avatar
Where is the # 4 plug located?
Old 05-31-2011, 07:37 AM
DarylJ's Avatar
THe driver's side front is 1. The passenger's side front is 2. Keep counting odds and evens back. So that puts #4 at the second one from the front on the passenger's side.
NCLR
11-26-2014 01:34 PM
kdscott100
04-15-2014 12:46 AM
BMW576
05-07-2013 04:32 PM
Rover5150
02-21-2008 10:21 AM
flavorking
02-10-2008 12:33 PM
Quick Reply: Rough idle until warm
