Rough idle when cold and getting worse
I have a 00 with 116K and it is idling rough when cold and is now idling rough when warm. I have changed the plugs and wires in the last 10K. I had an O2 Sensor issue a couple weeks ago and that has been fixed. Could this be and IAC issue something simple like a clogged fuel filter? I appreciate all your help and if I forgot anything please ask and I will do my best to help you help me.
You could try an IAC cleaning. Unbolt it, spray it down with O2 safe carb cleaner and knock the gunk out. Make sure to let it dry out before re-installing it.
It could also be your mass airflow sensor.
You throwing any codes?
What type of wires/plugs are you running?
It's definitely not a fuel filter.
