Rough starting,
Old Nov 19, 2018 | 06:06 AM
johnsjoiholm's Avatar
Default Rough starting,
Hello,
Fairly new to the LR game -- but loving my Disco 2 (Basic 2000-year model) TD5, which I picked up about a month ago. It runs great, once it gets going. As the weather has been turning nippier in the past 3 days, it is getting harder to get it cranking though. Not sure if there is a correlation. It is not cold enough to warrant the diesel to need heating up.
At this point, if I let the vehicle sit in ACC/II key mode for 2-3-5 minutes every time I am to start it up, it works just fine. While it is sitting in ACC/II mode, the battery and oil light will be solidly lit up; as it should.
If I don't give it a few minutes after trying to get it started in ACC/II mode it does not seem to start at all.
At first I thought it was the battery, but I checked and not only is the battery fairly fresh (manufactured in August 2018) it seems to charge and discharge just fine.
Otherwise the vehicle works great, except for that I have had to put a bit of coolant in every week, left speaker is busted, and it makes me feel like I am lording over all the peasants on the road in their BMW sedans.
Old Nov 19, 2018 | 06:50 AM
mollusc's Avatar
Does the fuel pump run with the key in that position? If so, I would be looking at low fuel pressure. Running it for a couple of minutes might be allowing the pressure to build to an acceptable level.
Old Nov 20, 2018 | 12:45 PM
dgi 07's Avatar
Originally Posted by johnsjoiholm
Hello,
Define nippy....
Check fuel pressure while cold and check to see if it bleeds down overnight. may be a regulator issue.
If its fine, my guess would be glow plugs. who many miles and whats your ambient temperature on startup ?
TD5's have a regulator so that needs to be factored in as well.
Capt_sensible
Oct 16, 2018 01:12 PM
Phatrowles
Aug 29, 2013 12:34 AM
Disco_stu97
Nov 28, 2011 07:14 AM
kjgale
May 19, 2011 08:41 PM
BigDogg
May 28, 2010 04:08 PM
