Rover will not shift out of park
Old Aug 8, 2006 | 02:02 PM
marlymarl's Avatar
Default Rover will not shift out of park
My car 2000 disco II with only 57,000 miles will not shift out of park.
Please help???
Old Aug 8, 2006 | 04:19 PM
xb70valkarye's Avatar
Default RE: Rover will not shift out of park
How mechanically inclined do you feel? Ususally the cause is mechanical in the forms of screws or nuts that have come loose. These are parts designed so that you have to push on the brake pedal and push the transmission lever button while the key is on the on position. In most cases the problem is right by the transmission selector lever itself. Did you ever have problems taking it out of park before or problems removing your key after putting it back in park? You might want to do a search in the forums too since I have seen detailed explinations about it on here before. Hope this helps and my guess is right.
Old Aug 8, 2006 | 06:43 PM
ORIGINAL: marlymarl
Please help???
90% chance you have a bad brake light switch which is located at the brake pedal. Do your brake lights work when pushing on the brake pedal?
Mike
Old Aug 8, 2006 | 08:34 PM
97DISCOIDAHO's Avatar
I blew a turn signal fuse about a week ago which caused the truck to not shift out of park. You may want to check that... pretty simple fix. The fuse blew from plugging a trailer into bad trailer wiring.
Old Aug 9, 2006 | 02:35 PM
geoman's Avatar
Hi!
This problem surfaces quite often on the Discovery. Check out the information at http://www.eurotekapg.com/bde.html that details the cause and a way to sometimes get around the problem long enough to get your Discovery to a shop without having to spend $$$ for a tow.
Regards,
Mike McLaughlin
Northern California
Old Aug 14, 2006 | 03:35 AM
katbri's Avatar
My 2000 Disco II did that too..... in a Starbucks drive thru!!! After pumping the brakes over and over it finally came out of park. It was the brake light switch. The dealership charged $80 bucks to fix it. Then, it happened again after 6 months. I now have an extra one in my glove box! (only $15-17). Good luck!
Old Aug 21, 2006 | 11:59 PM
marlymarl's Avatar
Thanks for all your help. It was the brake light switch.
[:@] Now I have just encountered another problem
My passenger door will not lock using the fob or the central locking button inside the vehicle. I can only
lock the passenger door by manually pushing the lock down.
Can anyone tell me what the problem could be????
Old Aug 22, 2006 | 01:07 AM
ajh's Avatar
ajh
Has anyone done a brake light switch override? Seems that off-road something like this would be pretty useful if it happened somewhere you really could get back out of.
Old Aug 22, 2006 | 09:34 AM
Different Drummer's Avatar
You guys are making me want to replace the brake light switch once a year just for good measure.
Old Aug 22, 2006 | 12:32 PM
ORIGINAL: Different Drummer
That switch is a good thing to keep as a back up.
Mike
