RoverTyme Lift 3"
Old Jan 11, 2008 | 10:47 PM
flattrakker's Avatar
Default RoverTyme Lift 3"
Im planning on lifting my D1 sometime soon.. Im highly interested in the RoverTyme 3 incher. Im wondering how much other stuff ill need to get this thing rolling with a lift.. they sell the kits but it says "3 and 5 inch lift kits do not include driveshafts" so I know ill need a drive shaft but what else isnt included? Is this a good lift system or should I look elsewhere?
Thanks!
Old Jan 11, 2008 | 10:57 PM
llesra's Avatar
Default RE: RoverTyme Lift 3"
everything you need comes with the kit. ive got the rte 3" kit with bilstein 7100 shocks and i recommend it. youll need to convert the rear driveshaft from the rotoflex to a u joint and get a double cardan driveshaft in the front. you can get those here http://www.4xshaft.com/Landrover.html
Old Jan 12, 2008 | 07:54 AM
If you still have the factory rubber brake lines, then I would also suggest you switch over to the stainless steel lines for the extra length as well as better pedal pressure.
Old Jan 12, 2008 | 02:24 PM
johnnybob06's Avatar
How expensive and how much time would it take to switch out those lines? I've heard great things about the steel ones :]
jpmiller
Dec 30, 2012 05:05 PM
faturbo
Nov 5, 2009 01:46 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
