Rubber plugs on oil pan
Old Apr 6, 2020 | 07:58 AM
BigCountry's Avatar
Unhappy Rubber plugs on oil pan
I followed the wonderful write up on how to change the oil pump and timing chain. While I had the oil pan off, I removed the rubber plugs on the bag which were caked with oil. After I fully cleaned the pan and was ready to reinstall, I cant get those sorry plugs to go back in for nothing. I want to get them in before I climb back under the truck with the pan. These are the flywheel plugs. I know it has to be something simple, but I cant get them in. Please help.
Old Apr 6, 2020 | 08:09 AM
Rackolamb1's Avatar
I ran into the same thing when I pulled the pan on my 04. The issue is that they are swollen from oil saturation over the years. I gave up and bought a couple new ones. The size difference was crazy. I don't think you'll be able to get them in the way they are now if they were anything like mine.
Old Apr 6, 2020 | 08:32 AM
HuskerRover's Avatar
Yes, they have swollen and will need replaced. In the meantime, cover up the holes with tape or something until you can get new ones.
Old Apr 6, 2020 | 08:35 AM
BigCountry's Avatar
thanks guys. Where do you get them and what are they called?
Old Apr 6, 2020 | 09:06 AM
https://www.roverparts.com/engine/ga...eals/ERR7229G/
or you could measure the hole and see what's available at your hardware store.
Old Apr 6, 2020 | 12:33 PM
JUKE179r's Avatar
Good idea @HuskerRover. Both of mine are missing so I’ll use my micrometer and mic it out.
Old Apr 6, 2020 | 02:39 PM
BigCountry's Avatar
thanks so much
sayeedA
Jan 30, 2018 02:43 PM
peterh
Feb 9, 2015 07:45 AM
peterh
Feb 8, 2015 01:31 PM
chargersfan
Aug 25, 2007 12:22 PM
jconway
Jun 20, 2005 03:21 PM
