Rugged Tire Recommendation
Old Oct 7, 2019 | 08:32 PM
Sean Maginness's Avatar
Originally Posted by thom_77
What size are you running those BFGs? Is your truck lifted?
Mine is lifted. Tires are 265/75/16
I go taller would change the center diff to 1.3 or 1.4
Old Oct 9, 2019 | 07:49 PM
jrncsmith's Avatar
Ver nice Sean! Thanks to all for the replies as you guys have, as usual, steered me in the right direction once again!
Old Oct 10, 2019 | 05:50 PM
jemler01's Avatar
3rd Gear
Default BFG AT's
Others have photos of their Goodrich A/T's, but I'll add my 2 cents, as I have them on my Expedition and my Disco 2. I'm also in PNW.
Get the LT tires, you can go higher with the pressure, so a bit better gas mileage. I've been using the same tire for 4 years now and I drive ALOT.. all over OR and WA, regardless of the weather.
Old Oct 11, 2019 | 07:09 AM
The A/T KO2 I'm running are E rated. I typically run them around 45psi warmed up for roads. They will go much higher psi but 45psi seems about right.
Have some valve mounted psi sensors and the tires start about 38psi and warm up to 45psi on a warm day or with a load. Bit over 45psi on really hot days and/or really loaded down (4 people + dogs + gear + roof cargo)
LR03NJ
Mar 8, 2016 10:26 AM
KernowDiscovery
Nov 28, 2013 07:33 PM
Tapper
Jun 1, 2011 05:48 AM
Spike555
Mar 20, 2009 07:18 AM
03 Disco SE
Aug 18, 2008 08:33 PM
