running board hardware: the long bolts
Old Jun 22, 2015 | 09:26 AM
ge234's Avatar
Default running board hardware: the long bolts
hey guys,
so i was putting the running boards back on yesterday and of course, when i was putting the last long bolt on the body mount, i sheered it off. unbelievable.
it's a 99 d2, anyone have any idea how to am going to find one of these weird bolts, its a rear one.
Old Jun 22, 2015 | 11:25 AM
mln01's Avatar
The same thing happened to me years ago. I was able to find one from one of our well known parts recyclers. Try Paul, Will or Marty for starters.
Otherwise I think you can put together a replacement using bolts or threaded rod, nuts, washers and a galvanized pipe nipple. I know that's what I was looking at doing before I found my replacement. I think I posted something about doing that on one of the forums a long time ago but I can't find that post right now.
Old Jun 22, 2015 | 01:26 PM
Andrew0's Avatar
The previous owner of my 2001 D2 removed the running boards. I have the running boards but don't plan on putting them back on. The bolts are still in the mounts on the truck though. If I can get them out (which I planned on doing soon anyway since I want to get rock sliders) you can have them.
Old Jun 22, 2015 | 03:48 PM
ge234's Avatar
hey andrew, that's very nice of you! i am a newbie on here as well. as long as you spray some rust penetrator on first and let it do it's job all you need is a 13mm wrench to hold the top of the bolt (which is above the triangular body mount) and the long bolt is a 15mm...hopefully it'll come right off for you. i'll obviously pay postage so let me know!
Old Jun 22, 2015 | 04:53 PM
Andrew0's Avatar
I'll check it out tonight or tomorrow. I'm positive they are still there, I always see them when I go under. They are definitely long. I'll let ya know.
Old Jun 22, 2015 | 07:12 PM
ge234's Avatar
thanks for this, how do i get in touch with those guys?
Old Jun 23, 2015 | 01:41 PM
mln01's Avatar
Here you go. All three are well known on this and other LR forums. You can also PM each of them here.
I thought Andrew0 was going to give one to you.
User name Paul Grant
paulgrant@mac.com
classicroverparts@gmail.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Will Tillery
User name will.tillery
434.251.9331
www.roverguy.com
willtillery@roverguy.com
Marty (I don't recall his last name)
Goes by drillbit on the forums
Purveyor of fine used Rover Parts
270 576 7922
Old Jun 23, 2015 | 08:19 PM
Andrew0's Avatar
Hey I checked earlier today and this is what I have -- not sure if it is what you are looking for: They look like long studs, two on each side, it's actually a long hexagonal cylinder that a 17mm wrench fits on if I remember correctly and some threads coming out the bottom of it, which a 15mm nut fastens to. I have all four and all four nuts. Is this what you are looking for?
Old Jun 24, 2015 | 08:50 AM
ge234's Avatar
hey andrew, that is them! awesome. if you dont mind i would love to have all four in case i sheer another one off. can i cut you a check for your time and the postage?
Old Jun 24, 2015 | 04:15 PM
Andrew0's Avatar
Personal Messaging you right now!
blast20
Nov 26, 2010 11:04 AM
Chrisinhouston
Dec 12, 2007 09:08 PM
Chrisinhouston
Nov 16, 2007 09:37 PM
don_r6
Aug 29, 2007 09:30 AM
kend500
Apr 27, 2006 02:43 AM
