Running hot...
Old Jun 17, 2012 | 04:43 PM
jfall's Avatar
Wondering..
If you put on the A/C to LO on both sides.
And just idle and idle and idle..
How hot will it get?
I had a BMW 735i which in traffic did not get too hot.
But, on the open road got hot.
This did not makes any sense.
Turns out the A/C condenser in front was plugged with airborne dirt, bugs, straw. The radiator less so - but plugged too with all that plus grease.
On my new (to me) Discovery II - I bought a can of GUNK which removes engine grime.
Sprayed it into the radiator and the A/C condenser.
Went to a self car wash and back sprayed the fins with high pressure - but not enough to bend the fins with pressure.
I did bend some fins getting the pressure hose nozzle way down in there.
Darn.
I did notice today - when I was climbing out of Boulder at 5,300 feet to Estes Park at 7,300 feet - I could hear the roar of the large fan - fan clutch had engaged and it was really pulling the air.
Thinking when you are really running hot - if you go to neutral and then to 2,000 RPM, the cooling fan should really roar and you can tell it is spinning.
I would really try to clean out junk from your A/C condenser first.
As you have a new rad, that is probably fine.
Pik
Mar 27, 2013 08:00 PM
94svt50
Jul 8, 2012 03:31 PM
LRScott
13
Apr 7, 2010 02:26 AM
twmj1953
Sep 29, 2009 09:49 PM
dgstringfield
Jul 12, 2006 12:17 AM
