Running temps
More speed & more heat with no real increase in air flow thru the tiny Grill/Radiator.
I’m seeing 188-211F right now in lovely SETX. With temps in the 90’s 100% humidity, AC on full blast, and 65-75MPH. Not all concerned. It’s 215F and not dropping that I’d be curious about.
D2’s with a stock OEM style thermostat will rise & fall temp wise. On long trips I see all my D2’s (with OEM style thermostats) rise & fall over time. If it was just one out of my 3 D2’s I’d be suspicious, but they all do it, 99, 02, and the 04.
@Ben Matheson That is what I see on mine too, it sits at 183ish at 60 mph below 25 deg C then runs up to 188 -197 as the temps get above around 28 deg C. Long steep up hills do the same, but it drop once I clear the summit.
I’ve been wanting to ask the same question re: my temps - and more less confirming my thoughts.
Truck had paperwork & I spoke to owner of garage who regularly services the truck thru out it’s life with previous owner. I got into the truck as it came out of shop from head gasket & radiator replacement. - I was steady at 184-188 occasionally 194 highest.
This was just after I did in line mod 125k mi on clock
8 months ago I exploded my rear carier & while I rebuilt, I changed my gears to try 4.47’s.
i still keep rpm in around 2000-2500. So
going slower, and just this summer swinging temps above 194 - 206, 208. Now 196k mi. Where I was not seeing this previously.
Curious life expectancy of a Nissan radiator or original fan clutch. Water pump replaced within 10k miles.
Manbeer
04-05-2017 08:51 AM
