Running temps
Old Jul 25, 2019 | 12:14 PM
Ben Matheson's Avatar
Default Running temps
My truck runs 185 on the hwy at 60 MPH regardless of weather but on a 600 mile trip back to Florida I noticed in 95 degree heat running 80mph it sat at a steady 195.
Thoughts? Granted running at 80 is working the motor more than lower speeds
Old Jul 25, 2019 | 12:36 PM
Best4x4's Avatar
More speed & more heat with no real increase in air flow thru the tiny Grill/Radiator.
I’m seeing 188-211F right now in lovely SETX. With temps in the 90’s 100% humidity, AC on full blast, and 65-75MPH. Not all concerned. It’s 215F and not dropping that I’d be curious about.
D2’s with a stock OEM style thermostat will rise & fall temp wise. On long trips I see all my D2’s (with OEM style thermostats) rise & fall over time. If it was just one out of my 3 D2’s I’d be suspicious, but they all do it, 99, 02, and the 04.
Old Jul 25, 2019 | 12:55 PM
Richard Gallant's Avatar
@Ben Matheson That is what I see on mine too, it sits at 183ish at 60 mph below 25 deg C then runs up to 188 -197 as the temps get above around 28 deg C. Long steep up hills do the same, but it drop once I clear the summit.
Old Jul 25, 2019 | 07:37 PM
Saturnine's Avatar
I’ve seen as low as 136 downhill in the mountains and as high as 215 sitting in Denver traffic when it’s over a 100 out with AC on
Usually at 190-194 without AC
i have inline setup with 180 tstat
Old Jul 25, 2019 | 08:00 PM
Thanks guys I'm feeling pretty good about the old girl. In the last 2 months I've done 4 600 mile trips and she's run like a champ and 2ft deep river crossing without the dash lighting up. Got to use CDL in the mountains and downhill assist.
Pretty pleased at this point
Old Jul 25, 2019 | 08:05 PM
Best4x4's Avatar
Yep she sounds good to go to me! I truly enjoyed my D2 at last years 2018 HCRR & it was SO much more enjoyable to drive off road vs any of my setup Jeeps. Manual Mode, TC, and HDC worked flawless.
Old Jul 25, 2019 | 08:14 PM
CDL made some pretty steep muddy roads feel like i was driving on pavement. I do believe you could drive this thing up a tree and down the other side LOL
Old Jul 25, 2019 | 09:49 PM
SundayFunday's Avatar
I’ve been wanting to ask the same question re: my temps - and more less confirming my thoughts.
Truck had paperwork & I spoke to owner of garage who regularly services the truck thru out it’s life with previous owner. I got into the truck as it came out of shop from head gasket & radiator replacement. - I was steady at 184-188 occasionally 194 highest.
This was just after I did in line mod 125k mi on clock
8 months ago I exploded my rear carier & while I rebuilt, I changed my gears to try 4.47’s.
i still keep rpm in around 2000-2500. So
going slower, and just this summer swinging temps above 194 - 206, 208. Now 196k mi. Where I was not seeing this previously.
Curious life expectancy of a Nissan radiator or original fan clutch. Water pump replaced within 10k miles.
Richard.rover
Jun 5, 2020 01:44 PM
Brandon318
May 31, 2019 10:09 AM
GCBurke
Mar 21, 2019 04:54 AM
Manbeer
Apr 5, 2017 08:51 AM
bballjames
May 31, 2012 09:29 AM
