Runs Hot - Sounds Like A Diesel
If you have a shop vac, it's pretty easy to check for leaks in the exhaust system by connecting the shop vac from it's outlet to your tail pipe so that the shop vac is blowing into the tail pipe. You can then use a spray bottle with some soapy water around the exhaust connections to see where you get bubbles. Sometimes you don't even need to spray the soapy water;you can hear and feel the leak.
![](https://cimg3.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/5b85d0a0_23f2_41ad_b277_c54f3df1b171_1027e18fc4cd0fac8571e2b3743eb7da808a0d4e.jpeg)
Brandon318 (10-12-2019)
Pulled the stat and put in a genuine 180 stat. Flushed all the coolant out. Running with water and purple ice - no coolant.
Before
idle - 210 to 215
1500 rpms - 210 to 224
2000+ rpms. - 204 to 212
After
idle - 194
1500 rpms - 183 to 188
2000+ rpms - 179 to 183
Fixing the exhaust leaks tomorrow!
Before
idle - 210 to 215
After
idle - 194
Before
idle - 210 to 215
After
idle - 194
Before
idle - 210 to 215
After
idle - 194
