Rusty Rear Frame rails (ugh!)
Old 08-25-2015, 09:03 AM
june82000's Avatar
Originally Posted by clint70
So found this thread... but not sure it will be as helpful as I as hoping... has anyone else had any experience with this?
link: https://landroverforums.com/forum/di...-please-49412/
Thank you
How'z about some pictures of that rust?
Old 08-25-2015, 03:59 PM
clint70's Avatar
So... finally got the time to get some video of the rust. I think the rear section from Rovers North might work. But thoughts??
Old 08-25-2015, 05:40 PM
krammark's Avatar
An air needle scaler will make quick work of the flaking rust and let you know how bad the rust has spread. Your right side looks like it goes under the tow attach bracket. Left side does not look too bad.
Old 08-25-2015, 08:53 PM
Two Rock's Avatar
You don't need that expensive rear frame section your rust is contained to the bottom of the frame mine was worse than that I dropped the tank cut off the exhaust, fuel tank and tow brackets made two u shaped repair sections cut out the rust then slipped the repair sections over the frame rails and welded them in then welded the brackets back on, cost me the steel and the materials. A metal band saw was key to making the repair pieces.
The following 2 users liked this post by Two Rock:
clint70 (08-26-2015), krammark (08-26-2015)
Old 08-25-2015, 10:11 PM
bosshogt's Avatar
I have found a lot of cool repair kits on eBay UK. I think these Rovers are more common like Fords and Chevy's over there. Check these out, weld on pre-cut. Get a nice welder or have a repair shop do it for a deal. It could easily be done on a Saturday with a grinder and wire wheel. The Disco shown in the video is pretty well eaten alive. Glad they use sand and Chloride here in Colorado. Yikes
Rear Chassis Leg Repair kit for Land Rover Discovery 2 TD5 II panel rail welding | eBay
The following 2 users liked this post by bosshogt:
clint70 (08-26-2015), lordmorpheus (08-26-2015)
Old 08-26-2015, 06:21 AM
krammark's Avatar
Can you post pics of your U-shaped pieces and where it was welded to the old frame? Was your U-shaped one piece with vertical cuts to allow the bottom to bend along the frame?
Old 08-26-2015, 06:57 AM
lordmorpheus's Avatar
Awesome find Bosshogt! Bookmarked for when I get around to tackling my rear frame cancer.
Old 08-26-2015, 08:18 AM
Two Rock's Avatar
I don't have any pics as they were lost when my phone was lost but each repair section was made from three pieces of steel welded together and matched the rear frame and was made just a bit wider so it could slide over the damaged section, it was made wider and higher than the rusted section so it could be welded to good steel, I'll take a pic of it installed.
Old 08-26-2015, 10:06 AM
Two Rock's Avatar
Found some pics of the job after all, the rust was extensive because the PO used the truck to launch his boat in saltwater. Most of the welding was done with a 120v lincoln flux core wire fed welder. The weld joints on the repair section were sealed with seam sealer and painted from the inside before I welded it on to prevent it from happening again.
Old 08-26-2015, 11:53 AM
Daedrix's Avatar
Banned
Racer X (08-26-2015)
Quick Reply: Rusty Rear Frame rails (ugh!)
