S.O.S. Studs from Catalytic Converter to Exhaust Manifold
Old May 1, 2024 | 05:34 PM
PNW_disco2's Avatar
Thanks for the tip. I got one and they came off real easy!
Old May 1, 2024 | 05:35 PM
PNW_disco2's Avatar
Very cool. Do you also sell the gaskets to the pipe?
Old May 1, 2024 | 05:48 PM
PNW_disco2's Avatar
Great tip. I didn't know that. Thanks!
Old May 1, 2024 | 05:52 PM
PNW_disco2's Avatar
General question... @Extinct @Richard Gallant @The Deputy @Discorama and anyone else
The exhaust manifold to pipe gaskets are cracked down the middle. I don't have the part and it won't show up for a least a week, at which point, I will have to leave the state for 6 weeks. I want to keep working. Is there any harm to me continuing the HG re-install with the old exhaust manifold gaskets and then swapping them out at a later point?
Old May 1, 2024 | 06:12 PM
Extinct's Avatar
Originally Posted by Harvlr
And whatever you do make sure you use anti seize compound on the threads when you reinstall.
I prefer silicone, last longer and still prevents rust. Also prevents vibration loosening.
Old May 2, 2024 | 12:56 AM
Discorama's Avatar
Christian from LRTime (Youtube) recommends copper grease all the time. He boasts that he never has problems getting things apart again after he treated the surface with it (he has been doing Land Rover repair videos for years). I think of getting a bottle of it.
Old May 2, 2024 | 04:52 AM
The Deputy's Avatar
Originally Posted by mln01
Just because Doug recommends replacing the studs doesn't mean it's required. Sometimes "If it ain't broke[n] don't fix" applies. This may be one of those times.
My original thoughts were the same, but...when you have a exhaust manifold laying right in front of you...that is the time to change them. Especially, if you are upgrading the quality of stud and nut. Nothing more disappointing, than to install manifolds and a year later have to go back in there and snap a stud.
Old May 2, 2024 | 08:08 AM
mln01's Avatar
Yeah, I agree with that. Worth an attempt, but I wouldn't go nuts if one gives you trouble.
Old May 2, 2024 | 09:09 AM
JohnZo's Avatar
Regarding a gasket cracked down the middle: That is not a sealing surface (the Y-pipe side has a gap) so it can be used again. Maybe red silicone to seal good on both gasket faces. Exhaust leaks have been my bane.
Old May 2, 2024 | 01:27 PM
PNW_disco2's Avatar
I decided to go with the haste makes waste motto and pull the studs and replace them all with new hardware since the manifolds were such a PITA to get to and are right in front of me.... Thank you all for tips/advice
HopeItsNotAMoneyPit
Nov 7, 2023 09:45 PM
Richard Gallant
Mar 14, 2020 05:01 PM
britguy
Sep 22, 2019 05:34 PM
Luckyjayb
Jan 16, 2017 08:34 PM
Jabez
May 20, 2011 10:10 AM
