SAI pump starting while driving?
Old Mar 22, 2019 | 07:56 AM
Roby466's Avatar
Default SAI pump starting while driving?
Good morning, quick question, not a major issue but I started noticing the SAI pump starts sometimes after startup. It seems even after driving a good 20 minutes, it will sometimes kick in at idle. Is this normal? It didn't do that before... no CEL and no other issues.
Thanks
David
Old Mar 22, 2019 | 08:48 AM
JUKE179r's Avatar
Mine does that too. The engine control module cycles the SAI pump on & off depending on emissions output during cold weather.
Google exothermic reaction.
Old Mar 22, 2019 | 10:36 AM
GCBurke's Avatar
normal
Old Mar 22, 2019 | 11:11 AM
Roby466's Avatar
Thanks makes me feel better. I was wondering how it could figure that it needed to run the SAI after a while driving... cats cooling down somehow? weird.
Old Mar 22, 2019 | 11:12 AM
jfall's Avatar
Sure. SAI will run in the morning when the engine is cold and you are driving
That is what it is supposed to do.
It is to quell pollution.
Your engine is not hot yet so the SAI will run.
Old Mar 22, 2019 | 11:13 AM
04in719's Avatar
Pretty normal.
Happens to me in winter often. My deduction is the difference in the temp at the intake manifold and the temp at the bottom output sensor of the radiator.
Old Mar 22, 2019 | 01:19 PM
redwhitekat's Avatar
Anyone know what parameters makes the sai run ?
Sometimes mine comes on when driving
sometimes it comes on on the first start of the day sometimes not. It’s weird
is it based on the o2 sensors
Old Mar 24, 2019 | 09:44 PM
ahab's Avatar
I suspect there's a problem with the SAI pump relay. Here's what the RAVE has to say.
The ECM checks the engine coolant temperature when the engine is started in addition to checking the elapsed time since the last engine start. The engine coolant temperature must be below 55°C (131°F) and the ambient temperature above 8°C (46°F) for the SAI pump to run.
There's no way your coolant is getting below 155° during normal driving. This could indicate a faulty Coolant Temp Sensor tricking the ECM into powering the relay (causing the pump to come on), but this would introduce other running problems as the mixture would be affected so my guess is that the SAI pump relay itself is faulty and causing the pump to randomly come on. Some other fault in the wiring could be shorting and causing the pump to run but the relay is triggered by the ECU itself so the relay would be my first guess. Also, in testing the pump itself by jumpering the relay it cautions not to let the pump run for more than 90 seconds:
Only allow the SAI pump to run for a maximum of 90 seconds and allow sufficient time for the pump to cool down before running again.
If it's running longer than that then that's another indication the ECM is not triggering the pump to come on.
Old Mar 25, 2019 | 07:05 AM
Sean Maginness's Avatar
My '03 D2 did this too. Turned out to be a vacuum line was cracked. Once I sorted that out the SAI has not cycled on after initial start.
Old Mar 25, 2019 | 10:54 AM
Roby466's Avatar
Interesting! Thanks for the info ahab, great find! Definitely worth checking my vacuum lines then. Which line caused it to cycle for you Sean?
