SAI Valve
Old Apr 5, 2021 | 01:03 PM
Dave03S's Avatar
Default SAI Valve
Anyone try one of these? https://smile.amazon.com/gp/product/...3360_576739000
Price is 1/10th the stock part. I've been getting a P1413 code and the pump wants to start and stop when the vehicle comes to a halt at a light for instance.
I figure it is either this or the SAI solenoid... but for $28.40 can you really go wrong?
The one on Amazon has only one review... hence my wondering if anyone else has tried this part.
Old Apr 5, 2021 | 01:47 PM
JUKE179r's Avatar
Have you tried cleaning out the old valve?
I did this to both of mine and blew out all kind of dust crap from inside the bellow (?). Works great.
Old Apr 5, 2021 | 02:23 PM
Dave03S's Avatar
I have not tried that, what exactly did you do? Just air? No solvents or cleaners?
Old Apr 5, 2021 | 06:22 PM
Extinct's Avatar
Have you tested yours? How do you know they are not working? Had 17 trucks so far and never had a bad one.
Old Apr 5, 2021 | 07:38 PM
Dave03S's Avatar
No I haven't tested it... Guilty as charged.
The cheap price made think about throwing a part at the problem... I know, I know...
In your opinion then, what is the most common cause of the 1413 code and the SAI Pump testing itself on stops, like at the end of an off ramp or randomly at a stop light?
Old Apr 6, 2021 | 07:01 AM
Extinct's Avatar
#1 issues is vacuum lines followed closely by the solenoid wiring, #3 would be the actual solenoid, #4 would be a frozen air pump but it sounds like you don't have that problem.
Old Apr 6, 2021 | 10:09 AM
Richard Gallant's Avatar
Mine has always been a vacuum issue those lines get old and the connectors get loose
Old Apr 7, 2021 | 01:08 PM
redrover75's Avatar
I was just looking at my p1412 and p1415 errors today, they come up intermittently. I did fix it on my last truck w a used SAI valve. I have visually inspected the vacuum lines, no obvious leaks, but I dont imagine they are easy to spot. I did a smoke test a while ago and could not find any leaks.
Is the EGR related to the SAI valve? Or, are the two an electrical fault?
Old Apr 7, 2021 | 01:27 PM
Dave03S's Avatar
I've also inspected the vacuum lines and they all seem secure. It looks like the 1413 code refers to "left bank SAI." I assume 1412 refers to right bank?
On these specific bank related codes wouldn't that indicate the only part of the system that has "banks" which is the valve itself?
Or am I just reaching?
Old Apr 7, 2021 | 05:44 PM
XRAD's Avatar
it's interesting to think about the SAI vacuum system. There is a reservoir, and then hoses from each side of reservoir to each air control valve. So does the reservoir have two separate vacuum chambers? I don't know, never took one apart. If the O2 sensor does not see the correct mixture on one side vs the other, then I guess a side specific code pops up. but the cause of this could be the valve, or anywhere along the course of the vacuum.....
