Sailing the Seven Seafoam?
Old Jul 13, 2012 | 12:16 PM
00Balls's Avatar
Default Sailing the Seven Seafoam?
Howdy!
What are the benefits of Seafoam, would you recommend using it, and if so, what/why/when is use recommended?
Thanks in advance for the insight!
Old Jul 13, 2012 | 12:44 PM
coors's Avatar
I'll let someone else chime in here. But I used when I first purchased my DII. I introduced it via the injection method. I'll periodically dump a bottle into the fuel tank every 3k miles or so.
Not sure if it's all a bunch of smoke (zinger!!) or it actually does something.
Subscribed
Old Jul 13, 2012 | 06:45 PM
In the gas tank once a year on a long trip.
Use quality fuels and you dont need a injector cleaner.
If you just got the truck not a bad idea to run 2 bottle over 2 tanks of fuel.
Techron is the best injector cleaner you can buy.
If you want to do a induction cleaning then buy the correct stuff, 3M induction cleaning kit, AutoZone, $35 for in the tank injector cleaner, throttle body cleaner and induction cleaner.
Follow the directions.
will_warne
Aug 5, 2009 05:16 PM
raid13
Mar 11, 2008 10:47 PM
Craig
Jun 19, 2007 09:49 AM
s4lex
May 2, 2007 10:10 PM
fridgefreezer
Mar 3, 2007 10:42 AM
