Same trans issue different trans
I just replaced the replacement transmission that I just installed in my 00. So this is my 3rd trans and second transfer case and after each one the vehicle still will not catch the gears and move. I went through the transfer case and the trans that is in it now came out of a 04 and was working perfectly. The previous trans was out of an 01 and was told it was in working order by someone I trust. I filled the fluid up correctly, replaced the filter correctly, correct fluid and installed it correctly. What would the next thing to check be? I heard the last trans spin when I put it into gear this one I don’t hear it. I do not have the front driveshaft on, rear is installed. Thank you
Richard Gallant (12-25-2020)
@RBS The other possibility is you are stuck between high and low (transfer case). You need to take a step back:
Next up do you get any dash lights at all ? It is in the realm of possibility the transmission TCU has died, but I believe the DIsco will still move in limp mode with a dead TCU however it may not, hopefully some one else can chime in
- drop both drive shafts
- put the transfer case in CDL lock
- put the transmission in gear
- Both output shafts on the transfer case should be turning
Thanks Richard, I will try anything now. Speaking of the dash lights, I am not positive I have all the correct electrical parts where they need to and are working. The T/C is from an 04 and I have the wiring harness for the 04 installed as well. I am yet to get any movement not even the sound of gears catching, if any of the switches like the two beside each other or the other two are bad will that keep the vehicle from moving?
