Say hello to my little friends.....
Old Dec 24, 2013 | 11:36 AM
dusty1's Avatar
Default Say hello to my little friends.....
Swapped axle 1/2s and diff in the front, all went fine.........except now 3 amigos. Am I correct in assuming it must be hub abs issue? Nothing else was messed with and all was cool with my braking prior. Do we agree with hub, culprit?
Thanks and feliz
Old Dec 24, 2013 | 11:41 AM
I'd double check the wiring connections to the sensors first. Doing all that work down there it's easy to pop something loose.
Old Dec 24, 2013 | 11:55 AM
ZGPhoto's Avatar
Last time I swapped diffs I dented the sensor and it caused the amigos, what was the code you got?
Old Dec 24, 2013 | 12:00 PM
jafir's Avatar
When I installed the lift on my 2003, I disconnected the rear abs sensors and it set a code. Maybe I had the key on? I'm not sure.
Old Dec 24, 2013 | 12:24 PM
dusty1's Avatar
No idea on code... Looking now for best deal hawkeye. I will check out the sensors first. The reason I assume that the problem is with a hub connection, is that I had some down time (waiting on axle seals) and excessively cleaned the hubs and sensor area. Could have been damaged/dented. I shall inspect connections and sensors.... Just making sure there is not another possibility.
Old Dec 24, 2013 | 12:27 PM
jafir's Avatar
Nanocom is on sale I think until the end of the year. 20% off.
Edit: maybe it ended already. They are closed for Christmas until January sometime.
Old Dec 24, 2013 | 01:19 PM
Externet's Avatar
My suspicion is growing that if a wheel is turned by hand during the time the SLABS compfuser is awake (that faint buzzing sound you hear for nearly half hour by the ABS modulator after any door/hood is opened) even whith no key in the ignition; the three friends show up.
Perhaps doing that kind of work/handling would be better with battery disconnected.
Please come back with findings whenever you resolve the issue.
Old Dec 24, 2013 | 01:43 PM
dusty1's Avatar
Externet, Will do and I did, in fact , disconnect battery before work. Quick connects... Makes 2second disconnect an easy task.
Jafir, is nano the way to go?
Old Dec 24, 2013 | 01:57 PM
jafir's Avatar
In my opinion, yes.
I've got both, and the nanocom seems to do more advanced things and because of the touch screen it is a little easier to use for many things, especially anything that requires data input. The nanocom will sync the ECM/BCU/Instrument panel and the hawkeye (as of version 5) will not. Nanocom makes keyless remote programming much easier. You can log many things to a file on an SD card while driving down the road, and then open them in excel on your computer. That way if you want to see before and after data on something like o2 sensors or maf sensors you can. Or you can more easily compare with other users.
You can also calibrate the SLS if you have it. And bleed the ACE system. The hawkeye might do ACE bleeding too, I'm not sure as none of my discos had it.
On the later Land Rovers, LR3, RRS, etc it really sings and dances. It will update the computers, and change settings that the hawkeye cannot.
Old Dec 24, 2013 | 02:42 PM
dusty1's Avatar
Thanks. I did some research (a lot of forum reading) looks like the only complaints on the nano are from the td5 owners......99 problems, but the diesel ain't one....,unless lack, there of, counts
Ace capable will be good too.
