Say hello to my little friends.....
Old Dec 24, 2013 | 02:46 PM
bballjames's Avatar
Originally Posted by jafir
The hawkeye might do ACE bleeding too, I'm not sure as none of my discos had it...
Yes you can bleed the ACE with the hawk eye.
Old Dec 24, 2013 | 02:47 PM
dusty1's Avatar
Is it still considered a hijack, if it's my thread. While I was researching I stumbled across the planned retro bronco 2015 plans. Cute. Awd 5.0 diesel
Old Dec 24, 2013 | 02:59 PM
jafir's Avatar
Yeah, on D2 nanocom can flash the TD5 computer, but the Td5 ECU doesn't have the failsafes that newer computers have, so you can brick it if something happens during the update. They've released updates for nanocom to help the matter, but there is still always a chance. No ECU updates available for D2 V8 using nanocom, so not an issue, and the computers in the D3 are much harder to brick.
I did just send an e-mail to Bearmach, and they are going to send me a CD for version 6 of hawkeye after the new year. I'm curious what features have been added.
Old Dec 24, 2013 | 03:01 PM
jafir's Avatar
Good to know. I thought it might, but I wasn't sure.
Old Dec 25, 2013 | 02:39 PM
dusty1's Avatar
1590 just means my amigos are on, right?
Old Dec 25, 2013 | 02:44 PM
jafir's Avatar
Yep. Just means that everything is working with the computer communication, but the SLABS is giving an error message to the ECU.
Old Jan 1, 2014 | 09:51 PM
dusty1's Avatar
fixed!!!! lonely again
code= weak front left signal. checked connections....good
fix= remove hub and sensor, cleaned both even vacuumed hub through sensor port hole with vac pump. needled in fresh grease, reassembled and presto. can't even keep those guys as friends
Old Jan 2, 2014 | 07:15 AM
drowssap's Avatar
the Hawkeye will bleed ace
triguy0220
Nov 5, 2013 09:28 PM
rawkey
Feb 28, 2012 06:58 AM
bestlasiks
Off Topic
Nov 26, 2009 12:45 AM
Landdaddy
Jun 13, 2006 11:27 PM
