Scanguage Owners - What's your Water Temp?
Old Nov 20, 2008 | 12:53 PM
rrhyne's Avatar
Default Scanguage Owners - What's your Water Temp?
I know a few of you are running ScanGauges in your truck. What water temps are you seeing on your discos? Vehicle type, year and miles please!
Mine usually reads 198 degrees at highway speeds, 200 with the AC on.
In hills and at lower speeds, I'm seeing 204-207 or so.
Highest recorded was 215, this summer, after running a while and then sitting in traffic. Scary?
99 DII, 107k
Are these normal? The rover gauge never gets off the middle. In fact it hits the middle of the gauge at 140 and i've never seen it rise past that, even when the scan gauge showed 215.
If you don't have a scanguage, I would definitely recommend it, as it provides error codes and numerical readout of things like voltage, water temp, intake air temp. Warning the cost per mile and gallons per hour readouts are depressing.
I updated my temps with some info from tonight.
Old Nov 20, 2008 | 01:00 PM
Disco2Guy's Avatar
Default RE: Scanguage Owners - What's your Water Temp?
I haven't set mine for water temp, but tomorrow when I drive to camp and surf in Santa Cruz, I'll set one of the gauges to water temp. It's a good hour and a half drive, and get to go through the Santa Cruz mountains so I should get some good readings for ya. My temp gauge never goes above the mid point either. I'll be home on Sunday.
'01 D2, 88K
Old Nov 20, 2008 | 03:59 PM
I dont have one, yet, it is on my must buy list.
215 is not a high temp, nothing to worry about until you hit 225, 230 shut it down. 250 your engine is toast.
Old Nov 20, 2008 | 05:26 PM
Darover's Avatar
Well, I was gonna get one, but it seems to me that per your post, it creates more worries than anything. And we all know that owning a Land Rover keeps an owner enough on its toes enoughas it is without adding to that.
I'm getting ready for a 16 hour drive over the week-end and honestly don't want to see where the temp will be during that trip. So the dash gauge is enough to keep me relaxed.
Old Nov 20, 2008 | 09:58 PM
rrhyne's Avatar
Thanks Spike.
Looking forward to your readings Disco2Guy, and I hope you get some waves. It's foggy and flat down here right now.
Darover, I'd recommend one. The error codes are reason enough, if you get stuck someplace without an autoshop you can call out for advice and maybe parts. I've cleared codes for a friend who ran his out of gas, turned the CE light right off. Also, i've never trusted panel gauges. Sending units fail all the time and you might not get a second chance after overheating your truck.
Old Nov 20, 2008 | 10:40 PM
Switzer's Avatar
My temps are the same as yours.
My Rover runs 200 + or - 10 degrees. The temps go up when the RPM's are low, probably from less coolant flow. Going down hills in gear drops it below 190. My factory gauge goes to the middle at around 155 degrees and doesn't move after that.
I've never had over 209 degrees. The factory coolant mix would boil over around 265 degrees. Most car engines run their best when the coolant is at or near 212 degrees.
Cheers,
Pete
Old Nov 21, 2008 | 03:24 AM
Disco2Guy's Avatar
ORIGINAL: rrhyne
Yeah, there's a big swell (6' -2' overhead) coming in right now. It's been 0-2' all week here too.
hilltoppersx
May 1, 2013 12:06 PM
spanky melton
Mar 30, 2011 10:57 PM
Rover Rebel
Jan 29, 2011 08:34 PM
Scanner
May 17, 2008 11:01 PM
