School me on hubs....
Mike just looking at the possibility of having to replace them....I currently have the intermediate three amigos I am in the process of getting the scan taken care of...I will do the three quart brake flush and inspect the hubs this weekend...I have had the truck for about a month just going through it and getting familiar with things that need to be addressed....
I had the amigos on and off for a while, then they stayed on. A scan said it was the right front sensor. The hubs seemed fine for a while but now I can hear one is definitely going bad even though I still can't detect any play in it. Anyways I ordered a new one with sensor from British Pacific for $240. That seems to be the best deal going, I'm not sure why though. There could be other reasons you have the amigos of course.
They are probably the proline hubs. I have not heard much about them good or bad so that is probably a good thing as they have been around a while. I will add that I've had 2 hubs fail that were OEM so I really would not mind giving aftermarket hubs a try.
I bought a front right on eBay last year and installed it as my first major drive component fix. If you watch used ones are $40 - $50 each on eBay. I would replace a few used ones a couple times before I paid $250 or $400. The most difficult part of the hub replacment it removing the disc brake rotor. Other than that a good puller and you be gentle removing the ABS sensor and its a easy DIY job.
