SE6-Third row add on
Old Mar 16, 2011 | 07:07 PM
gavone1976's Avatar
Default SE6-Third row add on
I was wondering if anyone has a step by step guide to add the third row to 99 disco.I just recently purchased ! jump seat ,both panels,headrest,seat belt,bracket and bolts for $100 and I just want to make sure I have all the required parts and that I do it correctly.
Old Mar 19, 2011 | 02:00 PM
humroot's Avatar
I don't know of one out there probably because it's really difficult and expensive to do. The floor in the rear of Disco II's that have the jumpseats from the factory have recesses where the seats lock down. From what I understand, if it didn't come from the factory with rear jump seats, those recesses aren't there.
Great deal on the seats, etc. though!
Old Mar 19, 2011 | 05:16 PM
You also need the floor of the 7 seater, unlike the DI you cannot just bolt in a third row on a DII.
Old Mar 21, 2011 | 05:21 PM
gavone1976's Avatar
I took the truck apart today and everything is there to mount all the brackets and seat belt so unless my truck was converted from a 7seater to a 5seater.I would imagine anyone with a 99 disco2 can also do this without any major changes(other than new upper and lower trim pieces) to the back of the truck.I just have to figure out where the lower seat belt bolts to,I found the main anchor point and shoulder anchor point I just need the lap anchor point.Any help with this would be appreciated.
Old Mar 21, 2011 | 08:51 PM
The latches in the floor are there too?
The seats latch to the floor when folded down for use.
Old Mar 21, 2011 | 09:14 PM
NiteTrain's Avatar
if those floor latches aren't there anybody riding in the back seat will probably be seriously injured or killed during an accident
Old Mar 21, 2011 | 09:39 PM
gavone1976's Avatar
I am going to try and install everything tomorrow,and yes There is a location for the latch in the floor.I wont know for sure until I physically try and install everything.I will keep you posted on the progress.
Old Apr 3, 2011 | 05:45 PM
gavone1976's Avatar
Finally got a chance to install everything today.Everything is in the floor latch is in,the holes were in the floor for the latch,the holes were in the sidewall under the window for the side mount on the seat.All the holes are there for the seat belt and the headrest.
Old Apr 3, 2011 | 05:51 PM
Sweet. So it was not as bad as we were lead to believe?
Everything is there you just need to bolt in the seats and latches and stuff?
Old Apr 3, 2011 | 05:56 PM
gavone1976's Avatar
Yes everthing was there,I was short a couple bolts so I went to Home Depot and matched them up and I was good to go.I didn't have instructions so I just looked at some pics from the web and figured it out.With a set of step by step instructions this would probably take about 3 or 4 hours to do both sides.I only did the passenger side.
