Sea Foam today!
Sea Foam today!
Well I screwed it up.. I put the hose in the bottle of sea foam and the other in the manifold and had a pair of pliers ready to go!
So I started it up and ran around the car to pinch the tubing and the bottle was empty!! It blew so much smoke I had 10 people watching the show well long story short it is more responsive and sound smooth. I will see my new MPG soon its got to be better than 11 MPG!Isthis normal a lot ofwater came out of the exoust pipe?
RE: Sea Foam today!
ORIGINAL: BADBUZzZzZz
Ask Discomike or send me your fax I coped his procedure to induction cleaning!
RE: Sea Foam today!
Leave the hose out of the can, start the engine, I used a funnel and poured it into the manifold, half a can, let it idle for a minute, poured the rest in and had mywife turn it off.
Let is soak for about 10 min while I put everything away and then took it onto the highway and drove the hell out of it for 20 miles.
Dont worry about the extra water coming out of the exhaust, better combustion means less waste which means better reaction inside the catalitic converters which means cleaner exhaust which means more water in the exhaust.
on
RE: Sea Foam today!
Do not use a funnel, use a smaal outlet and hose, all it to take at least 1 to 2 minutes to slowly suck in the fluid. When done turn the engine off and let it sit for at least 30 minutes before going and driving.
It will smoke, like a barn on fire for a good 15 minutes, so don't do this in your neighbor hood.
