Sea Foam today!
Old Mar 21, 2008 | 06:33 PM
BADBUZzZzZz's Avatar
Default Sea Foam today!
Well I screwed it up.. I put the hose in the bottle of sea foam and the other in the manifold and had a pair of pliers ready to go!
So I started it up and ran around the car to pinch the tubing and the bottle was empty!! It blew so much smoke I had 10 people watching the show well long story short it is more responsive and sound smooth. I will see my new MPG soon its got to be better than 11 MPG!Isthis normal a lot ofwater came out of the exoust pipe?
Old Mar 21, 2008 | 06:53 PM
Default RE: Sea Foam today!
Until you do it correctly, you won't see any changes at all.
There is an exact process to follow so the additive will work, without following it the chemical will just be burned off instead of soaked into the carb.
Old Mar 21, 2008 | 07:33 PM
Next time will be better but I do feal a differance in the idle and the responce? I spun my tires out of the drive way for the first time ever!! and I didnt mean too! What is all the water out of the exoust pip about?
Old Mar 21, 2008 | 11:27 PM
OJs DNA's Avatar
Mike, I've done a search but can't seem to locate the instructions for the seafoam treatment - can you point me in the right direction?
Old Mar 21, 2008 | 11:41 PM
Ask Discomike or send me your fax I coped his procedure to induction cleaning!
Old Mar 22, 2008 | 01:49 AM
OK just got back from a 120 mile tripe same day of my sea foam!!!
16 MPG!!!!! I was 13 MPG free way! 10 city! I will let you all know what my new city MPG is????
I also added a bottle of lucuse after!![X(][&o]
Old Mar 22, 2008 | 09:14 AM
OJs DNA's Avatar
ORIGINAL: BADBUZzZzZz
errrrr, no fax # here at home this weekend, is it to long to post? I guess all I really need is the info on which vacuum hose to pull, and if you pour it down a little at a time or if you let the hose suck it all up - those are the two areas I see owners on other forums talking about.
Old Mar 22, 2008 | 02:33 PM
Leave the hose out of the can, start the engine, I used a funnel and poured it into the manifold, half a can, let it idle for a minute, poured the rest in and had mywife turn it off.
Let is soak for about 10 min while I put everything away and then took it onto the highway and drove the hell out of it for 20 miles.
Dont worry about the extra water coming out of the exhaust, better combustion means less waste which means better reaction inside the catalitic converters which means cleaner exhaust which means more water in the exhaust.
Old Mar 22, 2008 | 03:12 PM
Do not use a funnel, use a smaal outlet and hose, all it to take at least 1 to 2 minutes to slowly suck in the fluid. When done turn the engine off and let it sit for at least 30 minutes before going and driving.
It will smoke, like a barn on fire for a good 15 minutes, so don't do this in your neighbor hood.
Old Mar 22, 2008 | 03:41 PM
OJs DNA's Avatar
Got it, did my 85 Toyota pick-up this morning using the brake booster vac line - but which vac line do I use with the Disco?
