Secondary air Pump
Old Jul 12, 2009 | 10:51 AM
isofast's Avatar
Default Secondary air Pump
Hi I have cleaned and changed filters on my Pierburg secondary air pump and it still sounds like a sick cat crying. Has anyone lubed the bearings WD 40 and run bench power to the pump and had any luck? I have searched the net and found limited info on this pump. Thanks in advance
Below you will find a link to Pierburg
Ernie
http://www.ms-motor-service.com/xima...012_en_web.pdf
Old Jul 12, 2009 | 12:58 PM
WD40 is the last thing I would try, it will just take out the bearings, if you want to do something like this find some specialty type of lube.
ljdiscovery
Nov 5, 2009 08:41 PM
kjgale
Jul 23, 2009 03:07 PM
charcoal grey
Mar 2, 2009 11:22 PM
jdelp
May 30, 2007 03:49 PM
akartis
Sep 25, 2006 01:31 PM
